gorganl2000 Posted October 12, 2016 Posted October 12, 2016 I know that now is the time to be making sure, I'm not rubbishing anyones suggestions.I'm just struggling to understand why I can go out and buy ACL/TAIHO/KING bearings in standard size, but these not be OK to fit to the car.Or, why I should be questioning a person qualified to carry out a task I've asked him to do? this is something that i've long discussed in the past....stock bearings have various sizes, which is all well and fine BUT aftermarket bearings are standard or oversized???...what gives?? Quote
TimD Posted October 12, 2016 Author Posted October 12, 2016 Well, some red plastigage is winging it's way to me, I hope it'll arrive in the post on Friday, that way I can at least check the mains before going away. Quote
TimD Posted October 12, 2016 Author Posted October 12, 2016 So, who's got a good guide, and what figures I should be looking for when using plastigauge? Con-rod oil clearance: STD = 0.016-0.048mm Limit = 0.08mm Main journal oil clearance: STD = 0.016-0.049mm U/S 0.25 = 0.017-0.061mm Limit = 0.08mm Can someone explain the above? Quote
TimD Posted October 12, 2016 Author Posted October 12, 2016 Looks like it'll have to all come apart anyway, something has gone wrong when installing the pistons. Quote
abbott Posted October 12, 2016 Posted October 12, 2016 (edited) Tim I wouldn't buy new ACL bearings due to there being made in China and changed manufacturing had a look at a set last time I was at robs and don't seem the same quality I know a couple people recently have bought original Toyota bearings instead. I can give you robs number if you wish if you require any technical info or input Edited October 12, 2016 by abbott Quote
TimD Posted October 12, 2016 Author Posted October 12, 2016 Thanks James, I understand Rob is a very busy chap so wouldn't want to bother him having not spent money there. I've removed a piston and rod to further inspect, hard to take pictures due to the light, I'll get some better ones in the morning. The lines run from the bottom of the cylinder to about 3/4 of the way up I wiped the assembly lube from the big end bearing, there are some marks on that too There are marks on the bottom and then both sides towards the top of the bearing Quote
fiddlersport Posted October 14, 2016 Posted October 14, 2016 did you use any lube while installing the pistons ? Quote
5e colin Posted October 15, 2016 Posted October 15, 2016 (edited) because rhey use a middle size bearing to be safe you could fit there size and measure up again and find out its right on the limit with tolerance and on boosted engine it will wear out faster the loose fitting bearing If you get what I'm saying.Could not quote the reply Tim on the shitty fone Edited October 15, 2016 by 5e colin Quote
Socks Posted October 15, 2016 Posted October 15, 2016 Please say yes Look dry to me Got more balls then me for trying it by ones self though. Credit where its due. Quote
00joeindastarb0 Posted October 16, 2016 Posted October 16, 2016 Plastiguage the bearings and I would imagine you'd be fine I did the same with Taiho bearings and the tolerances were at the tighter/midrange end of the scale which I was happy with touch wood😐 Quote
00joeindastarb0 Posted October 16, 2016 Posted October 16, 2016 But my original bearings were mostly 2 with the one 3 which you wouldnt be able to identify which one from the measurements I took. Quote
00joeindastarb0 Posted October 16, 2016 Posted October 16, 2016 The mains were tighter than the big ends if that's any relevance. Quote
triple j Posted October 16, 2016 Posted October 16, 2016 U probably have scoring on the crank from the look of that bearing there was 0 oil clearance there, I would be unsure about the bore scrapes maybe give the engine to someone that can build it properly before your out more money. Quote
PureRage Posted October 18, 2016 Posted October 18, 2016 any marks on the piston that caused the bore scrape? is the mark deep enough to feel it with your nail? or is it only visible but not detectable by feel? did you oil the cylinder walls before installing the pistons?the mark on the bearing is indeed a no oil mark. seems like the bearing is slightly too tight there. either wrong size bearing or some foreighn material behind the bearing that is making it too tight. make sure the bearing surface is clean before pressing in the bearing to the rod/cap. and this is why a std size isnt the best sollution. toyota made it in 3 sizes for a reason. the size diffrence is minute but can mean the world in the long run. Quote
TimD Posted November 1, 2016 Author Posted November 1, 2016 (edited) Hi Chaps! Well, I'm back from my holiday and ready to attack this! I did oil the cylinders, put not the rings or pistons, I can't feel the marks with my finger nail and have had some advice from others to suggest that I "should" be OK. But having said that, I'm going to remove the pistons and have the blocked checked over again by someone with a professional eye, rather than relying on photos on the internet so I'll report back on that one. I'm going to plastigauge the bearings as well. Not sure when I'll get another chance to look at this, possibly this weekend. Will keep you all updated! Money is not the driving force behind me doing this. I could quite easily afford to send it away and have it built up, but I want to learn how to do this, and that's what I'll do during this process. Edited November 1, 2016 by TimD Quote
5e colin Posted November 1, 2016 Posted November 1, 2016 then buy your own tools money wel invested Quote
