Hello and welcome to my progress thread on which will hopefully become my new hillclimb sprint car over the winter.
I am planning on using in the Scottish hillclimb sprint championship upto 2 litre road car class. Anyway the basis of the project will be a mark1 gt turbo 😆
The main plan is to use a small ct9 / ct12 hybrid turbo for as little lag as possible for our twisty tracks hopefully combined with its light weight , should give me a chance against all the clio's. ...
Cheers guys 😆
I have been slowly collecting bits over the last few months including a spare rolling shell as I've been known to push beyond my limits .....
The first car which I will be using came with a heap of spares including a spare engine 3 gearboxes 1 off which being an lsd box. Carbon bonnet , half size radiator , bucket seats , lightened flywheel , upgraded clutch and a few boxes full of things. So gave me a good start and as one will find over the course of the build im a bit obsessed with weight
20160919_184043.jpg.com/user/mike090184/media/Starlet%20ep82/20160905_195013.jpg.html]20160905_195013.jpg
Oh also ordered this a couple of weeks ago :)
  • 2 weeks later...
you will need to watch what you remove from the car in terms of interior as you could fall into the modified class which is slicks and alot more cost, im currently building a mk1 mx5 turbo to compete next year :)
Also be interested in what you plan to remove in terms of weight saving also
Something I need to look into myself
Phil
Edited by Phil
Aye your not wrong there's not much you can remove but all the little things add up 😆
Too start carpets getting ditched , sound deadining , alloy wheels 15x7 front and 13x7 rear for more weight saving , lithium ion battery 1kg compared to 7kg , willwood front calipers for more savings and carbonfibre centre silencer with side exit are just a few of my weight saving ideas time will tell
Is the wheel size change a comman change in class two?
Know you've plenty of background experience so keen to learn from your setup
Phil
Edited by Phil
Hi Phil
Aye it's not common in our class to use smaller wheels on the rear but the modified saloon class it's more common.
The main reasons for this is :
1. Lighter and cheaper tyres
2. Lighter and cheaper wheels
There has been a small bit of progress with parts arriving including my wepr ram horn ct9 top mount 😍 along with a dizzy blank . Must say the quality of the parts didn't disapoint almost a shame to fit them. Also I purchased a complete gearbox with kaaz limited slip diff which I will be building into one of my spare boxes . Now contemplating a charger cooler instead of the front mount
Great info cheers
What like is the spool with that setup ? I'm waiting to hear back about a ct12 hybrid with ct9 exhaust housing in presuming that's the same ?
I'm all about the spool 😆
Nice sounds like just what I'm after !
If the lad with the hybrid doesn't get back to me was also looking at racetechs stage 3 ct9 hybrid suposibly good for 250bhp?
