wakeabby14 Posted June 30, 2017 Posted June 30, 2017 (edited) Let me know your opinions guys i like the tf035 atm running at 1 bar but im itchinh towards td04. Have all supporting mods but im running Jam ecu not emanage.Main reason for debate is that i have a wepr td04 ramhorn kit coming from sacha in a few weeks and td04 has been on my mind for a while Edited June 30, 2017 by wakeabby14 Quote
5e colin Posted June 30, 2017 Posted June 30, 2017 Your going to regret going tdo4 all it spools so much later I used to get 1.1 by 3300 rpm the tdo4 is still dead at that rpm Quote
Gainzy Posted June 30, 2017 Posted June 30, 2017 If your planning forged I'd say td04L you make the most from the td04L 1.3 to 1.4 bar boost seen it loads of times Quote
wakeabby14 Posted June 30, 2017 Author Posted June 30, 2017 (edited) Im not going forged at the moment mabye next year, what was the hybrid tf035 you mentioned last time colin? The 19t cartridge or the billet upgrade? As want a tiny bit more top end than i have now Edited June 30, 2017 by wakeabby14 Quote
5e colin Posted June 30, 2017 Posted June 30, 2017 Ya tfo stock tdo4 for the forged boost pressure's most will be on stock engines tfo is best turbo around for stock engines 1bar or there about, tfo 19 t ya it is the same size almost as a ct12b with ct9b turbine shaft Quote
wakeabby14 Posted July 1, 2017 Author Posted July 1, 2017 (edited) On 6/30/2017 at 10:56 PM, 5e colin said: Ya tfo stock tdo4 for the forged boost pressure's most will be on stock engines tfo is best turbo around for stock engines 1bar or there about, tfo 19 t ya it is the same size almost as a ct12b with ct9b turbine shaft Ok will probs stick with the TF035 and sell my TD04L cheers guys! Edited July 1, 2017 by wakeabby14 Quote
Gainzy Posted July 1, 2017 Posted July 1, 2017 I'd go td04L more potential if you go forged later date and it's better for top end Quote
Ollieh17 Posted July 2, 2017 Posted July 2, 2017 Tf if you aren't forged td if you are. Not hard to change a turbo Quote
wakeabby14 Posted July 2, 2017 Author Posted July 2, 2017 (edited) You have given me a bit to think about cheers for that guys, what spring do you recon i should run in my ewg? I dont have an electronic boost controller so shall i just run a 1 bar spring all the time or be safe get a 0.8 bar spring and get a manual boost controller and do it that way? Also do you guys all run water and oil lines on your turbos as i only run my tf035hm on oil lines as a few people have said the water lines just cook your engine with all the extra heat? Edited July 2, 2017 by wakeabby14 Quote
wakeabby14 Posted July 2, 2017 Author Posted July 2, 2017 On 7/2/2017 at 1:43 PM, Amjad said: From a TF035 (4cm) user, go TD04LWorst case i can always go back to my tf035 i would like to feel the top end power of the td04l Quote
5e colin Posted July 2, 2017 Posted July 2, 2017 (edited) On 7/2/2017 at 1:43 PM, Amjad said: From a TF035 (4cm) user, go TD04L youd want the 6cm tfo great top end 49135 04700 and upwards Edited July 2, 2017 by 5e colin Quote
Gainzy Posted July 2, 2017 Posted July 2, 2017 On 7/2/2017 at 1:41 PM, wakeabby14 said: You have given me a bit to think about cheers for that guys, what spring do you recon i should run in my ewg? I dont have an electronic boost controller so shall i just run a 1 bar spring all the time or be safe get a 0.8 bar spring and get a manual boost controller and do it that way? Also do you guys all run water and oil lines on your turbos as i only run my tf035hm on oil lines as a few people have said the water lines just cook your engine with all the extra heat?You should buy an ebc 0.8 spring imo and I would run waterlines. This is why you buy decent gauge's to save your engine if temps and boost get too high Quote
wakeabby14 Posted July 2, 2017 Author Posted July 2, 2017 On 7/2/2017 at 9:38 PM, Gainzy said: You should buy an ebc 0.8 spring imo and I would run waterlines. This is why you buy decent gauge's to save your engine if temps and boost get too highCheers gainzy lad will get the water lines sorted and do a little saving and get the ebc, i.have wanted an ebc for ages anyway! Thanks bud Quote
gorganl2000 Posted July 3, 2017 Posted July 3, 2017 On 7/2/2017 at 6:10 PM, 5e colin said: youd want the 6cm tfo great top end 49135 04700 and upwards i agree...this is worth a try before the td04 swap Quote
gorganl2000 Posted July 3, 2017 Posted July 3, 2017 On 6/30/2017 at 4:31 PM, wakeabby14 said: Let me know your opinions guys i like the tf035 atm running at 1 bar but im itchinh towards td04. Have all supporting mods but im running Jam ecu not emanage.Main reason for debate is that i have a wepr td04 ramhorn kit coming from sacha in a few weeks and td04 has been on my mind for a while stick with the tf035 ,,,upgrade to the 6cm back end if you dont already run it from what you stated, this seems to be the better turbo for you. Quote
wakeabby14 Posted July 3, 2017 Author Posted July 3, 2017 On 7/3/2017 at 1:53 PM, gorganl2000 said: stick with the tf035 ,,,upgrade to the 6cm back end if you dont already run it from what you stated, this seems to be the better turbo for you. I dont really have the time to rebuild my TF035hm as im always working and dont have another car as my glanza is the daily, so im probs going to go TD04 now as im not too bothered about later spooling i want to feel the top end power of the TD. I really appreciate all the inputs from you guys i have made my decision! Quote
gorganl2000 Posted July 5, 2017 Posted July 5, 2017 cool boss . i hope you get everything sorted but i give you a few weeks before you miss the tf035.... Quote
5e colin Posted July 5, 2017 Posted July 5, 2017 Hey you selling the tfo I'm looking for 1 to rebuild Quote
Turbo Goose Posted July 5, 2017 Posted July 5, 2017 Depends where you drive and how you drive.Id go back to my TF035 if I still had it.I ran my TF on non forged engine and got full boost at about 3.5k rpm at 1.1 barI am now forged with TD04 and its full boost at 4.2k rpm at 1.4 barId sooner go back to TF035 and sacrifice a few bhp and the difference in lag is mega.Its annoying boosting around town with a TD04 as you got to wind it up and when you do it can come on too hard, the TF was much smoother around town Quote
Androo26 Posted October 2, 2017 Posted October 2, 2017 Well Ive got something a little different..... A 4cm TFO35 rear housing machined to fit a TD04. Good spool up with good flow. I also use a 35mm Turbosmart External gate. A fantastic compromise. Quote
Gainzy Posted October 2, 2017 Posted October 2, 2017 You can't get the full potential of the TD04 on a stock engine especially from a plug n play if I could go back I'd go TD04L only because I want to go forge if you want a town car ct9 hybrid ot depends on how you drive Quote
Bussey Posted October 2, 2017 Posted October 2, 2017 On 7/2/2017 at 6:10 PM, 5e colin said: youd want the 6cm tfo great top end 49135 04700 and upwards Best turbo I've ever used Quote
