So after photobucket going tits up i have chose to redo my build thread...
This is how the car looks after i picked it up..
Was a bit tatty but a good base to start.
1st off i removed the power steering
Then because its going to be a track car i decided to take the dash out and get rid of everything i wont need :)
Removed all the heating and loom i dont need which took a age!
Then i fitted my wheels because the others were damaged
Car needs a good scrub.
Then it was time to tackle the dreaded sound deadening and treat the rust i found
Then i had the headache of getting rid of every wire i dont need
Next job was to do the door card and get rid of all the wires and window regulators
Next i fitted the grill and new lip
Then i got the new inlet bolted on
Then i fitted some angle iron to mount the radiator further forward to make room for the turbo and new intercooler pipe route
Next prepping the rocker cover for welding
Then i cut my bonnet to fit the catches
Then i fitted the rear bar :)
Next i had a go at making perspex windows which still need finishing
The i gave the dash bar a lick of paint to brighten things up and you can see how much of the loom has gone
Then i fitted my turbo kit which im so happy with :)
Next is to give everything a good clean and get everything ready for paint :) this is how its sitting at the moment
Just need to finish the headlight cold air feed :)
More pictures to follow comments welcome.
  • 2 weeks later...
Another update on this still waiting on parts so progress is slow.
Finally got the doors sprayed and finished
Next i tackled the long job of relocating the engine bay fuse box to make some room.
This is where it will now live
Next got the rocker cover welded up
all fitted
And after spraying it various colours this is the colour i chose, Now needs to be prepped and properly sprayed :)
More to come soon comments welcome :)
Little update got my new catch can bolted on and bonnet struts
Next was to get the dash back in after it was flocked
And got my perspex windows finished just need to put black edge on the rear ones.
More to follow :)
  • 1 month later...
