richglanzav Posted August 13, 2017 Share Posted August 13, 2017 (edited) Hey guys i have 1 or 2 issues with my glanza. If i list the issue below could some of you starlet boffins try to give me an internet diagnosis? 1. the car judders really badly if i pull away without giving it some high revs. i mean like a standard below 3k rpm gentle pull away from a standing start. Literally feels like the engines gonna come loose lol. 2. the car makes a knock when boosting hard in 2nd gear and letting off suddenly. 3. car also regularly makes a knocking sound when pulling away slowly although my old td04 glanza also did this. The car needs some new wheel bearings anyway, but I was thinking of also getting polybushed mounts and new cv joints in the hope this will cure everything. But could problem 1 be the clutch being nakkered in some way? once car is moving its absolutely fine and no slippage at all. Edited August 13, 2017 by richglanzav Quote Link to post Share on other sites
Starlet__SR Posted August 13, 2017 Share Posted August 13, 2017 Rear engine mount Quote Link to post Share on other sites
Ryncewind Posted August 13, 2017 Share Posted August 13, 2017 If the only problem was the first issue id go with the clutch springs being snapped but with all the others id say the mount too, or maybe both lol Quote Link to post Share on other sites
Gainzy Posted August 13, 2017 Share Posted August 13, 2017 I thought engine mount issue from description to Quote Link to post Share on other sites
richglanzav Posted August 14, 2017 Author Share Posted August 14, 2017 Hmm yeh guys im gna give mike a bell and order the stuff see what happens lol Quote Link to post Share on other sites
5e colin Posted August 14, 2017 Share Posted August 14, 2017 Might be cluch to I just fitted 6 puck it Judders when taking of Quote Link to post Share on other sites
richglanzav Posted August 29, 2017 Author Share Posted August 29, 2017 Has to be clutch as judder is still bad even when engine and gearbox have powerflex mounts Quote Link to post Share on other sites
richglanzav Posted August 29, 2017 Author Share Posted August 29, 2017 Might just av a ride up to tuning developments. Get their stock clutch thats good for 190hp and stock new mounts fitted. Anyone want some just fitted powerflex mounts? Lol Quote Link to post Share on other sites
shaq Posted October 3, 2017 Share Posted October 3, 2017 Check your clutch bolts loose or missing and cracked mounts,sometimes the mounts okay can be a crack on where mounts bolt onto engine is cracked,I've cracked it and fixed twice taken to engineer,could be extra meat on new clutch or un evenly torqued bolts between gbox engine or even clutch plates,release bearing!l Quote Link to post Share on other sites
federalman Posted October 23, 2017 Share Posted October 23, 2017 I'm inclined to go with 5E Colin, my 6 puck judders so I'd imagine it'll be a combination of aggressive clutch and an engine mount. Quote Link to post Share on other sites
