16 hours ago, glanzadude said:
Are you not really over running the stock injectors at 220 as that is 90bhp over like?
No it’s fine. You’re pushing it when you’re getting around 240-250.
On ‎12‎/‎18‎/‎2018 at 11:01 PM, Healey said:
If you're worried about it, I used some yellow 450cc rx8 injectors that I got for £90 refurbished on eBay
Are these injectors direct fit (inc. electric plugs)?
Hi or low ohms?
  • 8 months later...
On 12/20/2018 at 5:49 PM, Healey said:
They are high and are a direct swap, get your tuner to put them when you go for a map
Have you got the link for these injectors mate. I had a fuel rail to go on but I need to buy an-6 to 8mm fuel pipe fittings etc etc. Seems a bit of a headache to do when there is direct swap injectors.
