Brad93 Posted June 15, 2020 Author Posted June 15, 2020 Haha I will give the car a detail once she’s mapped up, not sure what’s next on the list I just need to attack her and fit the lot, huge parts list to go on sitting waiting just need the time. Quote
Brad93 Posted June 30, 2020 Author Posted June 30, 2020 Bonnet struts fitted, nice simple install happy with them. Quote
Brad93 Posted July 5, 2020 Author Posted July 5, 2020 Started to strip back all the old unneeded wiring from the from loom, removing engine loom, emb, stock ecu ect all half out. Replaced the well known rocker cover for a polished one which has had the baffle partially cut for better breathing, AN fittings and coil pack mounts. Inlets off for something special to replace it. will try to keep some order of what I’m doing as I go but just attacking everything now. Quote
Brad93 Posted July 5, 2020 Author Posted July 5, 2020 Matts amazing welding hiding behind the bumper here. cheeky mishimoto oil cooler mounted in place ready for me to fit the rest once the wiring is sorted. Quote
Bopthebear Posted July 5, 2020 Posted July 5, 2020 Cool project mate some snail on it lol Keep the updates coming Quote
Brad93 Posted July 9, 2020 Author Posted July 9, 2020 So happy with the outcome of my new ACIS inlet manifold ! Decided this was the way to go, many changes along the way. HDF worked there magic and made my Audi DBW TB fit, faces machined flat and inlet temp sensor Thread tapped. Can’t wait to get it back and fitted. Quote
Sam44 Posted July 10, 2020 Posted July 10, 2020 Great work, very rare manifold. are you selling your corrola inlet? I'll give you £100 for it. Quote
Brad93 Posted July 15, 2020 Author Posted July 15, 2020 Thanks people 👌 Sam I may have a spare corolla inlet that I would sell but I’ll have to dig it out. some more progress and offered up the inlet, so happy with the outcome. Quote
Sam44 Posted July 16, 2020 Posted July 16, 2020 Thank you. if possible, what rpm will you be opening the big runners or does it open up both sets?. Was it the 5ehfe cams you had installed. Quote
Brad93 Posted July 16, 2020 Author Posted July 16, 2020 That would have to be set up on the dyno mate, pretty sure there’s only 1 line of butterfly valves on the inlet I can’t even remember what side but pretty sure the short runners are closed until you switch over which would open the lot. I’ll have to confirm had a lot going on atm brains all over the place. believe they are 5e cams I’m trying to identify them visually but no info online. Quote
Brad93 Posted July 21, 2020 Author Posted July 21, 2020 More progress tonight, found out the engine spec was different to what was originally sold to me as... not bad news though, eagle rods and Ross pistons, very happy with this ! Anyone else ever seen eagle rods for the 4e before ? I purchased a RW baffled sump, stripped and cleaned, sprayed and fitted this evening with some Honda bond. Quote
Brad93 Posted August 5, 2020 Author Posted August 5, 2020 First bit of wiring done, simple but pleased. Quote
Brad93 Posted September 4, 2020 Author Posted September 4, 2020 Took a week off work and got some bits done on the old girl. - old engine loom removed - wiring mods done to keep everything OEM working - new custom engine loom in place and through fire wall ( hated this part ) - fitted DevilsOwn water methanol race tank in boot with low level sensor and inlet drilled, wiring still required awaiting small bolts to mount solenoid - fitted new sensors in engine bay - mocked up fueling system, need to skim the corner of my TD fuel rail so DW 465cc injector plugs will fit, braided lines and high flow AN fitting ordered, Radium FPR+FPD mounted to rail, need a fitting to come for this also -x4 wheel speed sensors fitted and plugs on wiring made, ran Screened twisted pair to the front ready to be wired in to CAN module - fitted modified brake pedal and Clutch pedal, extra pedal switch mounts welded on, switches fitted few more goodies fitted, hard to keep up this week. Will try to get some better photos once everything is in place Quote
Brad93 Posted September 4, 2020 Author Posted September 4, 2020 -Moved engine bay fuse box to behind glove box, cut out back of glove box for access -fitted Bosch fuel filter Been fun working out how and where’s best to mount everything ect, really getting stuck in Quote
Brad93 Posted September 14, 2020 Author Posted September 14, 2020 - Haltech CAN hub - odyssey extream30 battery 9kg - usb to CAN - wheel speed to CAN - Bluetooth module - CAN add on module - data logger cheeky pic of the bay in its progressing state, coming along nicely. Quote
Brad93 Posted September 21, 2020 Author Posted September 21, 2020 Polished up the plenum after the sonic cleaner, came out well. Quote
RobSR Posted September 22, 2020 Posted September 22, 2020 Nice to see someone taking an interest in electronics on their build! Quote
