  • Replies 62
  • Created
  • Last Reply
Top Posters In This Topic
is this yours?spec?pics
Yes it's mine.
Eagle rod's.
YCP piston's (modified)
Standard block just honed/glaze busted. 0.004" p2w clearance at largest point.
ACL bearings
Gen honda head gasket.
ARP head studs.
Modified oil pump original 144k mile pump :p
Modified block and girdle for rods to fit.
Head work by myself.
Cheap cast manifold, (soon to make a new 1 but you never get time to do my own car)
Hondata s300, socketed and mapped by me.
6 paddle clutch, custom flywheel, (extra clamping force)
Lot's of little bit's to make it all come together.
At brunters it did
0-30 in 2.07
0-60 in 4.76 (did 58mph at the time in second gear ;))
0-100 in 8.93
quarter in 12.53 at 119.6 (limiter in 4th)
140.6 limiter in 5th i did raise the limiter but couldn't be bothered to do another top speed run as it was never going to be very good.
On the day the car weighed 930kg's plus fuel and me.
It's since had plastic windows and about 30kg's of weight removed from inside the car.
New engine will be built when i get chance for TOTB.
seen this in the flesh it looks a reyt sleeper (apart from now its got rota grids off his bros glanza)
seen/heard it go aswell it flippin amazing
yet to have a passanger ride in it yet though (hint hint rick ;))
and ofcourse all work done by himself a true testiment to his skills
and then theres hes evo :p lol
yet to have a passanger ride in it yet though (hint hint rick ;) )
Haha, cheers.
No engine in it, took it out the other day, new 1 will be done in 2 weeks ready to be run in for TOTB on the 27th!
so this is the fastest Sohc civic in the uk at the moment?
As far as i know this is the quickest on street tyres yes. Deffo the quickest at brunters where i had it timed.
Liam_D,
Yes it is.
Just picked up some new injectors and the block back from the machine shop got a bit more work to do on the block then going to put it back together later this week.
thats what i was thinking...were you there then tucka? i didnt see your car when i walked through the car park, but i did see a white V drive in from a distance..
na i was in my homies twin turbo supra dude, doin some work on my car at the mo tucked up in garage so she aint been out for a bit.
Here's a little vid of the Civic.
Are you a member of passion ford aswell. Im sure i've seen a thread of your car on there. My name is because!!!! on passion ford. For sum strange reason i cant get on the website since teh 27th of july, it just comes up with 'server cannot be found' <_<
Does this happen to you or is it just my internet bieng gay!!!
I badly want to know how the fords did at totb.
Nice civic
for those who asked yes it was him at TOTB with the holes in the bumpers
he blew a turbo up on the way down there so had to change his turbo at the side of the road lol
as far as i know he did a 12.5 but i left abit early so dont know if he did any better or anything
How did it go? :p
In a word badly, but i suppose it wasn't all that bad considering. I had a puncture the night before (stranded on m1 at 11 with no spare) so had budget tyres on the rear, i fitted off a mates car at half 11)
Set off at 6 and by 7 i was spannering the turbo off at the side of the m18 after a pretty caterstrophic failure. Anyway with 10 miles to run in and map a new turbo i suppose we did ok, i left the car on the rich side, which with the high inlet temp's and compensation maps the car was really rich on the strip.
i 'think' i may of seen this yesterday, will have to look through the pics..
If you've got any pic's or vid's stick them up here.
was this the one runnin at 10 of the best on sunday? with holes cut into the rear bumper to reduce drag?
Yes i was. :p
Are you a member of passion ford aswell. Im sure i've seen a thread of your car on there. My name is because!!!! on passion ford. For sum strange reason i cant get on the website since teh 27th of july, it just comes up with 'server cannot be found' :p
Nice civic
Site's sometimes a bit iffy. But not that bad.
Results for TOTB are all here.
http://www.redlinemag.com/
Yes i think my best was 12.53 at 112mph. I should have been doing over 120 terminals but it didn't happen on the day.
Managed a 4th in handling on my first run, (I braked for a corner that wasn't there as well) My second run i pushed a little bit harder.... a bit 2 hard. And sent it sideways through the cones. (good rear tyres) I never even pumped the fronts back up after drag so did the handling with 9psi in the fronts.
A long day but a good laugh. :p
