right mde up a new thread as when i sorted out my photobucket into folders it has got rid of the pics of here ;)
Bought a 4wd starlet of ebay for 640 quid with plans to strip it all back and make it a gt replica but going fully forged and 1.5 block
i swapped my white gt which was td04 lsd etc with a mate for his not so good looking gt
JUST A LOAD OF PIC'S OF STRIPPING DOWN AND SWAPPING BITS OVER
DONOR CAR
LOVELY BROWN DASH IF ANY WANTS IT:p
GEARBOX CLEANED UP
BUMPER CUT OUT, DASH SWAPPED AND COMPLETE LOOM
5E engine stripped down and forged
whats better than one fully forged 5e engine? 2 fully forged 5e engines:p
  • Replies 322
  • Created
  • Last Reply
Top Posters In This Topic
body work
some first pics of it outside
after running it it for a few miles, it got mapped at engine advateges made 240 at 1 bar hen when started to turn the boost up it started to det like mad, could of been a few things, after doing a couple k the turbo gave up so looked around for something a bit different, had loads of ideas
;):D
but went for a vf23 bb turbo, then got a custom mani made and downpipe from ricky lee, when the car ws apart got rid of aload of stuff that you dont need,washer bottles, horn, power steering and clean and tidy up the engine bay, different intercooler piping etc
went from this
to this
whole front end been repainted, inner wing's, and underneath, and interior removed and repainted
few things on order,
cusco 7 point roll cage, custom catch tank, custom battery box, overflow bottle, new seats, custom inlet mani,
will put spec up later on
SPEC:
ENGINE
5EFE BLOCK
4EFTE HEAD, CAM'S
CRUISE VALE SPRIGS
ZEP 1.2MM HG
PAUTOR RODS
WIESCO DISH PISTONS (10CC)
LIGHTEN AND BALLANCE BOTTOM END
AASCO LIGHTEN FLYWHEEL
5E BOTTOM PULLEY (WITHOUT PS PULLEY)
A/C COMPLETELY REMOVED
P/S REMOVED
ALLY CIVIC RAD
CUSTOM RICKYLEE MANI
CUSTOM RICKY LEE DOWN PIPE
HKS HI POWER SIDE EXIT
TIAL 38MM EXTERNAL WASTEGATE
SCREAMER PIPE
BRAIDED WATER LINES
BRAIDED OIL FEED AND RETURN LINE
IHI VF 23 TURBO
TRD ENGINE MOUNTS
CUSTOM BAFFLED SUMP
UNIVERSAL INTERCOOLER
CUSTOM 2.25" BEFORE INTERCOOLER AND 3" AFTER INTERCOOLER
FORGE DUMP VAVLE
CUSTOM INLET MANI
BILLET 75MM THROTTLE BODY
COOLING PANEL
NGK HT LEADS
HEAT RANGE 8 SPARK PLUGS
ACT FOUR PUK CLUTCH
CUSTOM CATH TANK
CUSTOM BATERY BOX
CUSTOM OVERFLOW TANK
FUEL SYSTEM
RC 440CC INJECTOR'S
CUSTOM ALLY FUEL TANK (25 LTR)
FUEL SURGE TANK
BOSCH 044 PUMP
LOW PRESURE FUEL PUMP
BRAIDED LINES
SARD FUEL PRESSURE REG
CHASSIS
4WD
15" 5 SPOKE
195/45 TOYO T1-4'S
ZEP RACING COILOVER'S
CUSCO FRONT STRUT BRACE
CUSCO LOWER ARM BAR
CUSCO 7 POINT ROLL CAGE
3G FRONT DISC'S
MINTEX PADS
EXTERIOR
FULL GT TURBO BODY SWAP, DOOR'S, BOOT, ARCHES ETC
FRONT BUMPER CUT OUT
AIREL REMOVED AND SMOOTHED
FUEL CAP REMOVED AND SMOOTHED
RESPRAYED MAZDA WINNING BLUE
CARBON BONNET
QUAD LIGHT CONVERSION
WHOLE UNDERNEATH PAINTED BLACK
TINTED WINDOWS
GREEDY SUNSTRIP
INTERIOR
COMPLETE GT DASH SWAP
GT COMPLETE WIRING LOOM
STRIPPED OUT BACK AND PAINTED BLACK
CARPET REMOVED
PROSPORT GAUGES
APEXI AVCR
THATS IT FOR NOW, PROB FORGOT SOME
One of my favourite builds on here, fucking insane!!
That custom inlet is the bollocks, must of been expensive
Do you want me to delete your other thread mate?
thatnks for the comments dude's.
i dont no who made the inlet mani as i am buying it from a fella in ireland, if dave b sells them he may no,
rob i used a 1.6mm hg with wiesco low comp pistons, i was runing bout 7.8-9-1 f the top of my head
done a few things today, aze_b come round and made me up a custom side exit with hks hi power back box, screamer pipe was made and braided water lines-oil lines fitted
also removed inlet in prep for new one
bottom pulley split as i dont use the power steering one, and a pic of aze welding which came out pretty cool :thumbsup:
cheers rick, na no longer need them now, had a few people on passion ford asking bout the mani, so expect some pm's over there :thumbsup:
Cool, i'm on with making a couple of cossy manifolds at the minute, PF is massive so hoping the word will spread a little :(
I'm just sorting some little tags out for the manifolds so people know what they are.
Cool, i'm on with making a couple of cossy manifolds at the minute, PF is massive so hoping the word will spread a little :thumbsup:
Ricky your gonna be busy in 2009 i tell you that, there is not that many great fabricators about which do work like yours. Good lick with it all get some window stickers off to me and gaz bit of extra advertisement for ya! :(
yeah mate passion ford is mad, by the time you have posted something and hit new post's, there are about 20 newer post :thumbsup: ,
send me a couple of them tags up mate, will put one on abbott's too
Ye, that'd be cool if you could, it'l be a week or so off yet, as i'm just finalising the design then they need to laser cut them.
