adz_sportif_turbo Posted September 16, 2009 Posted September 16, 2009 i am the proud owner of a sportif turbo... and in the process of completing the conversion!! inevitably I've ran into a few problems...but i hav got the engine running....and running sweet!! i got the car with the ecu wired in (not sure if fully correctly, but shees running) the rear glanza axle has been put in as well!! problems encountered are:-fuel pump doesnt work unless i bridge the diagnostic port-has oem lsd which i didnt know (found out when shafts didnt line up)...so need shafts and rear mount-engine management light on-dont think the fuel cut is wired correctly...wires to ecu jus hanging there!!-hks super drager exhaust doesnt line up with hangers-gear linkage braket wrong-oil light on very faintly...and becomes brighter when ran a bit. (personally think wiring fault)i think that is about it...i will post the link of sum pikkies so you get an idea of what she looks like!! if anyone has any ideas of solutions to these problems...please dont hesitate to give me a shout!!! i need al the help i can get!!cheers guys!! Quote
adz_sportif_turbo Posted September 16, 2009 Author Posted September 16, 2009 HKS super dragerengine when i got herwhen i got her runningshees home!!! Quote
adz_sportif_turbo Posted September 16, 2009 Author Posted September 16, 2009 1st mod....lowering lol Quote
Russleh Posted September 16, 2009 Posted September 16, 2009 ahhh i hate running into problems . only one i can relate to is the oil light. i had the wire for the oil pressure sensor on the coolant sensor bit. easy mistake if your rushing about. dunno if thats your problem but thats defo what mine was doin for a while. Quote
adz_sportif_turbo Posted September 16, 2009 Author Posted September 16, 2009 ahhh really!!! yes that would make sense also!!! are the connectors the same?? I've been abroad for the past 2 month so havnt been able 2 get my hands on it!! but i wil defo look at that!! cheers bud!! Quote
Russleh Posted September 16, 2009 Posted September 16, 2009 well the oil pressure one is like a little metal spade connector and the one that goes to my coolant looks like a male plug but tis actually a female lol slips over the wee sensor bit/. Quote
LukeSR Posted September 16, 2009 Posted September 16, 2009 Sure i have seen this before Liking the colour though mate Quote
200sx-Starlet-Jay Posted September 16, 2009 Posted September 16, 2009 im doing mine now as well fuel pump... check you have a live feed to it, or it wont wind up.exhaust hangers.. easy to fix, take it to an exhaust place when its sorted, or get a welder to come out to you and sort it out.rest of the problems you just need to keep an eye out on the forums, post up in wanted sections, and try all the jap breakers.good luck with it dude Quote
adz_sportif_turbo Posted September 17, 2009 Author Posted September 17, 2009 yhh i was gna chop the hangers and re weld themin the positions they needed....put them in the rubbers and match it up 2 the chassis, as for the fuel pump....my biggest worry :S!!!! ther is no power 2 the pump at all!! and ther is no relay clickin!! i need to know if the switched feed comes from the ecu....or jus an ignition feed?!?! it has a switched feed efi relay pin on the ecu....but when i look at wiring diagrams it looks like a feed comes from the ignition!! ne 1 help on that?? Quote
200sx-Starlet-Jay Posted September 17, 2009 Posted September 17, 2009 yhh i was gna chop the hangers and re weld themin the positions they needed....put them in the rubbers and match it up 2 the chassis, as for the fuel pump....my biggest worry :S!!!! ther is no power 2 the pump at all!! and ther is no relay clickin!! i need to know if the switched feed comes from the ecu....or jus an ignition feed?!?! it has a switched feed efi relay pin on the ecu....but when i look at wiring diagrams it looks like a feed comes from the ignition!! ne 1 help on that??im not entirely sure what it is as standard. im pretty muck making a loom for mine, and we have put the feed on ignition.. but goes through a switch first. so turn ignition on, then fuel pump. then start engine. the loom for it runs over the centre tunel on the chassis, i think from memory its the blue wire, but cnt be sure without going out and checking. that needs a live feed to it, and ure away. but make sure its from an ignition live, not permanent or it will keep running when you turn everything off, and kill you battery.Jay Quote
adz_sportif_turbo Posted September 20, 2009 Author Posted September 20, 2009 ahhh rite yeaa i fink im jus gona start again...and wire in my own!! im going 2 run an ignition feed to a relay for the electromagnet...and jus a normal constant feed on the other side of it!! that should be fine yea?? how a relay is normally wired!! how come you have ran it of an ignition feed but still put a switch in it jay?? for the novelty?? Quote
adz_sportif_turbo Posted December 16, 2009 Author Posted December 16, 2009 update...new gearbox and shafts in...clutch and brakes bled...diagnostics check revealed code 52?!?! knock sensor i fink!! but i drove her under her own power!! lovely!! thermostat housing cracked so need replacing!! next step: fmic and coilovers!! Quote
adz_sportif_turbo Posted December 16, 2009 Author Posted December 16, 2009 oh oil light on because connected 2 water temp...(russel u ledgened!!!)next update after test drive once i got the therm housing Quote
adz_sportif_turbo Posted March 31, 2010 Author Posted March 31, 2010 update!!! therm housing in a sorted...test drove her she goes lovely!!! 7 psi with the hi/low boost solenoid bypassed :S!! new actuator me thinks!! fuel pump wiring sorted, no switched ground from the ecu!! all wiring is now complete!! so bolted all the dash back in!! fmic by the end of the month, then exhaust n MOT . Quote
adz_sportif_turbo Posted March 31, 2010 Author Posted March 31, 2010 Glad the thermostat housing fixed it chap yeaa mate was great thanks!! u sent me much more than i was expecting which was a bonus!! Quote
DavidAshton Posted March 31, 2010 Posted March 31, 2010 I like the colour, the other half had one the same colour, i always wanted to turbo it. Quote
riko666 Posted March 31, 2010 Posted March 31, 2010 yeaa mate was great thanks!! u sent me much more than i was expecting which was a bonus!! Pay up Quote
adz_sportif_turbo Posted March 31, 2010 Author Posted March 31, 2010 I like the colour, the other half had one the same colour, i always wanted to turbo it.yeaa when i bought it i didnt evn know what colour it was ha...i jus knew it wer a sportif half finished!! tiz a bonus tho!! Pay up lol im a student u gota cut me sum slack !! naa much appreciated tho mateYour from Somerset? Never seen you around it will be boosting about in no time dw!! Quote
adz_sportif_turbo Posted March 31, 2010 Author Posted March 31, 2010 also i get a nice discount on new rota wheels ...I've had a look through the catalogue and im stil unsure on which ones to get?? anyone have any suggestions?? blurple is quite difficult to pick for lol!! Quote
Galliano Posted April 1, 2010 Posted April 1, 2010 White, Gunmetal Grey or Silver goes best with blurple IMO!Where abouts in Somerset are you? Quote
Amjad Posted April 1, 2010 Posted April 1, 2010 I agree with Galliano about the wheels Nice car you got here man, I keep looking at the thread and PP's N/A>4efte conversion price now I'm wanting to get my car turbo'd Quote
jason_l Posted April 1, 2010 Posted April 1, 2010 Getting there Mate Looked almost done when i saw it, except for the interior in pieces. Although i quite liked the stripped out no dash look Jason Quote
