  • Replies 1.3k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
prob has sorted the problem tbh. hes a top man and the work he does is quality. get it ordered. i got a wepr cap free with my order lol. ghetto
Ive had several problems with mine and he aint compensated me or helped me with it ive just had to bodge the problems n now gotta buy a few extra things to try help !
I wouldnt avoid hi though the quality is top notch , just teething problems
didn't he make you a downpipe for a standard exhaust but your exhaust in fact was a odd job? have i got that right? can remember seeing something.
nazz i had exactly the same fitment issue and it was minor tbh, just got the dremmel out and shaved down the ps pump bracket a tad, was no biggy, also he has now sorted it any way as it turned out a small handful where made on the wrong jig, again though cant stress how simple the fixes where took an extra 10 mins and the mani was on.
lew you cant go wrong with WEPR I've had a good few different mani's over the yaers yet always end up back with WEPR due to flawless quality! very strong and are the nuts tbh
i think ill be going wepr aswell one day when i can afford to turbo my brum :)
kits look awesome quality, none of that fannying about trying to make the welds look super neat, causing them to be weaker :)
Shorty - ive cut alot of the ps bracket there aint much left lol , but theres still the issue that the screamer is in the way so pushes the rad pipe abit , then the wastegate fouls the rad so much its nearly Put a hole through it and then the angle of the turbo pushes the oil filter offline and that also leaks, also cause of the oil return on the td04 is outta alignment with the sump whenever i put some piping on it it always split cause it kinks!!
So now i need to buy a relocator for oil filter , or some more silicon but single ply , then i have to move the rad somehow , and the screamer is 1.5mm SS so will snap if bent so i just have to hope it dont burn the rubber, and i dont knOw how to sort the oil feed return
if i didnt have my secret sport setup, tje only other kit i would buy is wepr, never head a wepr mani crack anjd any problems he always sorts it out, race tech seem to be cracking alot and he doesnt seem to resolves the issues, and the newer zisco ones seem to blow and need skimming before fitting
wepr all the way!!
i think these td04 kits hes selling now have the wastegate near the gearbox
does look tight to the rad on that picture i want to fit my sard rad so will have to see
My kit could of come with the wastegate down there but the lOnger hosing etc makes boost control a lil weaker plus i was worried if i accidently bottom out i might hit it , then things like stone flicking up or going through puddles n sheite like that
wepr all the way!!
havent read one bad review about his work apart from nazz had a few teething problems
As above, what have you opted for? :(
How many Race-techs have failed? Yes WEPR are immense and I've just fitted a WEPR kit to my car, but why are people slating Race-tech without any proper evidence etc? Not a dig as you personally but it just seems a bandwagon thing, one persons cracked and people have slated Race-tech for nothing. I bought a TD04 kit off Ricky too and his service and parts are ace.
