Sparky Posted May 15, 2011 Share Posted May 15, 2011 Awsome work Ed its getting there sounds mint My Type S sounds pathetic at .6bar :lo: Quote Link to post Share on other sites
Idrees Posted May 15, 2011 Share Posted May 15, 2011 Good stuff, good luck with getting the little problems sorted! Quote Link to post Share on other sites
whiteglanzav Posted May 16, 2011 Author Share Posted May 16, 2011 Awsome work Ed its getting there sounds mint My Type S sounds pathetic at .6bar :lo:lol cheers matey i am gunna have to adjust it to hard so that i can get more flutter out of it glad u like it tho dude - it makes me feel warm inside Good stuff, good luck with getting the little problems sorted! Cheers Iddy - and i have the best part still to come HRF ep91 front Quote Link to post Share on other sites
shorty Posted May 16, 2011 Share Posted May 16, 2011 Well done ed is turning into a real beast now you thinking 550's arnt man enough then??mine was hitting 1.4 bar at 4500rpm, but turns out there have been 3 boost leaks so poor old turb was prob boosting like 1.7/1.8 seems ok though tbh. Not sure what the vf35 are like for max boost but my 24 seems strong obviously not boosting her much atm as the map is shite now the leaks are fixed. But enjoying seeing all the vf's graphs now just need a graph from bean too. Quote Link to post Share on other sites
whiteglanzav Posted May 16, 2011 Author Share Posted May 16, 2011 Well done ed is turning into a real beast now you thinking 550's arnt man enough then??mine was hitting 1.4 bar at 4500rpm, but turns out there have been 3 boost leaks so poor old turb was prob boosting like 1.7/1.8 seems ok though tbh. Not sure what the vf35 are like for max boost but my 24 seems strong obviously not boosting her much atm as the map is shite now the leaks are fixed. But enjoying seeing all the vf's graphs now just need a graph from bean too.cheers dude wel i don't think that its 550cc's aren't enough i just think that its MY 550's that aren't quite up 2 it i have had them sat at mine for at least a year and god knows how long they'd bin out of action before that - and they ain't even SARD ones just stock rx7 so i'm guessing that they might be a bit old n past it lol (just like john if your reading dude love you)yer the boost leaks are a real killer check out the difference in these two graphs before and after the boost leaks, one at 16.9 psi with a boost leak and then one at 20 psi without a boost leak, you can clearly see how the boost comes in a lot earlier with a lot more force - the leaks will not have given your figure any good either !! i cant believe i had to turn it back down it would be completely savage with another 30 whp lol and then again if it was another 50 its gunna be mental.i cant wait to see beans graph either REPRESENTING.... IHI lolololol Quote Link to post Share on other sites
whiteglanzav Posted May 16, 2011 Author Share Posted May 16, 2011 ^ Quote Link to post Share on other sites
ro55ifumi Posted May 17, 2011 Share Posted May 17, 2011 Quality Edd, stunning build my boy an mat be old but not past it yet Agree on the 17psi nice curve till ya get bigger injectors John Quote Link to post Share on other sites
RYPIEGLANZAV Posted May 17, 2011 Share Posted May 17, 2011 Loving it ed looks beaut !!! Quote Link to post Share on other sites
CRAIG-SR Posted May 17, 2011 Share Posted May 17, 2011 Ed took me out in this earlyer, What a epic Starlet, its mint.Loved it, Put a rite smile on my face lol Watch out for this at japfest2 Yo. Quote Link to post Share on other sites
Bean Posted May 17, 2011 Share Posted May 17, 2011 im sure i posted in here before but i cant see it. anyway....hopefully you will get it sorted mate, keep us updated as i want to see what it will make, im still running mine in. mine seems to go lean when boost comes in so i have added some fuel into my map but still the wideband is showing its running lean and doing strange things. i think its faulty so im going to check the wiring and see how i get on. im dying to get some boost ran through it. Quote Link to post Share on other sites
whiteglanzav Posted May 17, 2011 Author Share Posted May 17, 2011 yer man its all the little niggly things that take the longest to sort !!where did you go to get it base tuned what kind of wideband did they use ??when you get it up and running at 1.5 bar in 2nd gear with 4 wheel drive it will shift like fuck mine shifts at 1 bar with fwd its amazing !!And cheers Craigy Boy :P Quote Link to post Share on other sites
Bean Posted May 17, 2011 Share Posted May 17, 2011 its an old td04l map from tuning developments, ive only been running really low boost and keeping an eye on the afr's so are you hoping changing the injectors sorts it out? ive got a set of almost new sard 550's to go in mine. ive got an acis inlet too but i want a bigger throttle body on it first. Quote Link to post Share on other sites
whiteglanzav Posted May 18, 2011 Author Share Posted May 18, 2011 its an old td04l map from tuning developments, ive only been running really low boost and keeping an eye on the afr's so are you hoping changing the injectors sorts it out? ive got a set of almost new sard 550's to go in mine. ive got an acis inlet too but i want a bigger throttle body on it first.yer i am hoping by changing the injectors that it sorts it - i think that these could just be tired so we will have to see how it goes,if not i may have to upgrade the fuel and ignition system a little - but i am sure it will be worth it for an extra 50 wheel horsepower how does it idle and what does it drive like on the down run of revs ?acis inlets are sweet i think its just a matter of finding someone who knows how to link it up with the ecu etc but it should give you some decent gains Quote Link to post Share on other sites
Bean Posted May 18, 2011 Share Posted May 18, 2011 the stock ignition system should be fine for what were goin to be running on these turbos. So long as its in good condition, cap and arm, leads and decent plugs. Is your timing definetly on the 4e marks? Im going to be running a dta s60 ecu so controlling the butterflys wont be a problem, I've asked the mapper about it.Mine ticks over around 1k or just over. I've got 2 polly engine mounts so having the idle a little higher helps with the vibrations lol. It drives really nice and smooth up and down the revs. Quote Link to post Share on other sites
Ryan5793 Posted May 18, 2011 Share Posted May 18, 2011 awesome! i need those breaks in my life! nice work. Quote Link to post Share on other sites
whiteglanzav Posted May 18, 2011 Author Share Posted May 18, 2011 the stock ignition system should be fine for what were goin to be running on these turbos. So long as its in good condition, cap and arm, leads and decent plugs. Is your timing definetly on the 4e marks? Im going to be running a dta s60 ecu so controlling the butterflys wont be a problem, I've asked the mapper about it.Mine ticks over around 1k or just over. I've got 2 polly engine mounts so having the idle a little higher helps with the vibrations lol. It drives really nice and smooth up and down the revs. aye thats what i thought about the ignition system from readin up on it - thats y i am pointin at the injectors lolyer idling a little high helps the vibes lol i may adjust mine up a tad but it aint bad !well as long as alls goin smooth get it run in and get it mapped haha !!!!!!awesome! i need those breaks in my life! nice work. cheers dude yer the brakes are awesome Quote Link to post Share on other sites
Socks Posted May 18, 2011 Share Posted May 18, 2011 this is looking fantastic. ull hav to leme no wen your next down at wills ed im only a 20min drive from his unit... as i am from yours! x Quote Link to post Share on other sites
Bean Posted May 18, 2011 Share Posted May 18, 2011 aye thats what i thought about the ignition system from readin up on it - thats y i am pointin at the injectors lolyer idling a little high helps the vibes lol i may adjust mine up a tad but it aint bad !well as long as alls goin smooth get it run in and get it mapped haha !!!!!!thing is i want to get some boost through it while im running it in but i dont know how safe i am to to do it lol. why dont you get those injectors cleaned and flow tested?my tuner told me some really good injectors that are well priced but i cant remember what they were now lol. if the 4wd dyno was finished i would just get the car ran in on the dyno then get it all sorted out. Quote Link to post Share on other sites
whiteglanzav Posted May 18, 2011 Author Share Posted May 18, 2011 thing is i want to get some boost through it while im running it in but i dont know how safe i am to to do it lol. why dont you get those injectors cleaned and flow tested?my tuner told me some really good injectors that are well priced but i cant remember what they were now lol. if the 4wd dyno was finished i would just get the car ran in on the dyno then get it all sorted out.yer man i may well do that - i was told rc injectors are supposed to be good and well priced aswell,but its all gunna have to wait for a month or 2 as i have a lot going off in this time ill not bore ya with the details lol but dont worry i sharnt be hangin about !!sexual!Thank you Quote Link to post Share on other sites
whiteglanzav Posted May 25, 2011 Author Share Posted May 25, 2011 More pictures - test fit of the sides - one wasnt quite right - i only found out after i painted it so iddys sortin me a new one, also fitted my HRF spats to go with the bumper, i think i may have the most HRF'd Glanza now ?? and of course some d1 spec nuts because they are porno Quote Link to post Share on other sites
Bean Posted May 25, 2011 Share Posted May 25, 2011 never mind the bodywork, get it sorted and mapped! ive adjusted my map a bit and had a tuner check my afrs on the road with his wideband as mine is faulty and its running ok. slightly rich at top end so nice and safe for now. im running almost a bar through it now. seems to go well. its not as fast as mini valvers gt but it comes on boost so easily! Quote Link to post Share on other sites
whiteglanzav Posted May 25, 2011 Author Share Posted May 25, 2011 hahaha - seriously i am happy with the very safe power that it has at the minute but i will get it mapped further just need to get my 2 week malia binge out of the way first as well as moving house and sorting out all the office things before next week lol and the body work is just as important : - note how the front bumper is completely foooked haha i may well rock the full slag look for a bit - its kool, oh and i adjusted my dump valve to the hard setting i love the flutter bu i may adjust it a tiny bit softer so i get a slight whistle too i bet yours sticks to the road like mad dunt it ??? Quote Link to post Share on other sites
Bean Posted May 25, 2011 Share Posted May 25, 2011 sounds like your going to be busy! you should see mine looks ruff as lol. yeah it gets it down fine, for now lol. i checked on the progress of the 4wd dyno the guy is making and its looking quality, really coming together now, im dying to get my car on it. ive told him i want to be at the front of the line for when its finished! Quote Link to post Share on other sites
JDMtuning1 Posted May 25, 2011 Share Posted May 25, 2011 you got the kirts then! looking well i fitted the bumper i bought off you and have a white glanza bonnet on aswell now its getting there slow;y but surley!.andyy Quote Link to post Share on other sites
