Greetings to all from frosty Russia!!! Excuse for my bad English language. I will use the dictionary. I have bought the car one year ago, it was in a standard complete set.
In the engine everything has been changed practically, at present we are engaged in a suspension bracket and brakes. Don't judge strictly. With pleasure I will answer all your questions. Mike
88cd06d480faed53-large.jpg88cd06d4acbf5a7c-large.jpg88cd06d4bb6df74d-large.jpg88cd06d4ce71d55d-large.jpg88cd06d4e175b36e-large.jpg88cd06d5242ce4bc-large.jpg88cd085b7ee2b798-large.jpg88cd0e9fde810223-large.jpg88cd0e9fedab6682-large.jpg88cd0e9ffc2343ac-large.jpg88cd0ea0126aa4bd-large.jpg88cd0ea026210a02-large.jpg88cd0ea0655df8a9-large.jpg88cd0ea0a5607988-large.jpg88cd0ea0b54e0ebd-large.jpg88cd11d23e8884fe-large.jpg88cd11d27ebaa161-large.jpg88cd11d2a982bcae-large.jpg88cd11d2e220d792-large.jpg88cd159e3e77af83-large.jpg88cd159e4c8df442-large.jpg88cd159ea5f0806c-large.jpg88cd15a024f28a22-large.jpg88cd15a036798c07-large.jpg88cd15a04894233c-large.jpg88cd15a067d956f6-large.jpg88cd15a077f687b1-large.jpg88cd15a0a1e14304-large.jpg88cd220659c0c825-large.jpg88cd220666f0276a-large.jpg88cd220676729eb3-large.jpg88cd22068cee5e09-large.jpg88cd22069a3a4dd1-large.jpg88cd2206a83d878e-large.jpg
88cd551104020218-large.jpg88cd5fb0027c6efe-large.jpg88cd4f1b4da77438-large.jpg88cd220759d4511f-large.jpg88cd220769e7fc59-large.jpg88cd2207770b74bc-large.jpg88cd2207b469eecc-large.jpg88cd22080fed9615-large.jpg88cd22084e733ac7-large.jpg88cd2314f1ffe6af-large.jpg88cd23151761027c-large.jpg88cd23153d17cfd4-large.jpg88cd23155891d21d-large.jpg88cd2315ce76994f-large.jpg88cd2315fb0a1e31-large.jpg88cd2316886957f7-large.jpg88cd2316be3af4a9-large.jpg88cd249b1c41c8aa-large.jpg88cd249aeed0e3cf-large.jpg88cd249ad3841bab-large.jpg88cd270a74653ceb-large.jpg88cd270a86255fd6-large.jpg88cd270a571fd10d-large.jpg88cd2964cfc3dc32-large.jpg88cd29659fbdb6c2-large.jpg88cd2965f30b7ef9-large.jpg88cd3e75592639da-large.jpg88cd3e7488ec1a22-large.jpg88cd3f2329e776e8-large.jpg
88cd6601e38d6cdd-large.jpg88cd660210eb46b6-large.jpg88cd65c606e6a720-large.jpg88cd842814ada358-large.jpg88cd84283462b7bf-large.jpg88cd3a449c04e738-large.jpg88cd270c2b044ce8-main.jpg88cd085d5046e14a-large.jpg
amazing build thread dude
is that the cruise pink? do you have the paint code, because a few members would like to know the paint code.
did you make the exhaust manifold yourself too?
i dont think your english is all that bad either.
ryan
great work!! thanks for putting all the pictures up. Do you have a full spec list for the car? im interested in the inlet you made, is that a celica throttle body your using? any dyno figures?
amazing work!
what turbo and power?
looks like it will make crazy numbers!
loving the front exit, ive got one of those.
ryan
hi ryan, Color has been picked up in manual by mixing. The majority of details in the car it is made in manual as well as a exhaust
Results of testing while aren't present. The intel is custom and taken from Supra
In the project beginning there was an idea to make the toy car because it to be pleasant to my daughter pink as at HKS.
spec list:
â?? Ross racing pistons, pins and rings (bore-74mm, 74.5mm, 75mm)(compression 8.2:1 and 8.0:1)
â?? Scat forged rods with arp bolts
â?? Complete engine gasket set( all seals and gaskets for rebuild- 4E Genuine Toyota oem kit)
â?? Conrod bearings
â?? Main bearings
â?? Thrust washer
â?? NGK iridium spark plugs grade
â?? Custom made metal head gasket for 4efte engines. 1.8mm thickness multilayered steel gasket.
â?? 460CC INJECTORS
â?? WALBRO HIGH PRESSURE FUEL PUMP
â?? ARP HEADBOLTS
â?? 265 Degree Billet Camshaft
â?? turbo GT2871R
â?? civic Radiator
â?? japan Intercooler
â?? HKS Blow Off
â?? Vibrant branch pipe
â?? Samco Silicone Hoses
-custom made exhaust
-custom intake
-custom made Engine support
-Transmission шы с54+с56
-LCD
-300 BHP CLUTCH KITS
-suspension TRD+cusco
-brakes Toyota Levin BZR
-wheels russian special order 4.5kg and Toyo R888
-Electronic devices is Defi and AEM
There is still a set of improvements
welcome along buddy!!
there has been loads of work put into this,
and that engine.......WOW!!! lovely colours aswell
gonna be one mean starlet when its done
keep it up!!
