right s i thought it was about time i got myself a project to work on, i picked a shell up from turbodave on the weekend to use as a base.
So plans for this are to make it a light as possible and use it as a track/weekend car
Intended plans
  • custom built roll cage using t45 45mm tubing
  • forged engine(more on that later)
  • perspex windows all round
  • fiberglass doors, boot, bonnet and wings(hoping to do the whole shell at some point)
  • full respray unsure on colour (opinions???)
  • titanuim exhaust from down pipe back
  • custom loom to get rid off all the crap i wont be needing
  • 4 pot brake kit
  • haltech ecu
  • 2 x bride rep seats
  • charge cooler
thats all i can think of for now apart from the obvious braces arb etc
every part will either be powder coated, polished,or painted and every nut and bolt will be replaced with high tensile stainless
started stripping all the crap out today dash heaters etc so the cutting can commence
few pics of how she stands
more up dates to come
Project looks good mate,
As for the sound deadening, I used a heat gun and a scraper. Just heated the tar like stuff and kept it hot and kept scraping. Takes a while and if it goes cold it goes hard again
Weighs a hell of a lot thou
Gary
^^^ cool will it not just clog up the wire as its almost like tar?will give it a go later
No mate it will just rip it straight off. I did all my inner arches with it and the sound deadening in the boot.
thanks for the comments guys
@amjad im undecided on turbo choice yet
engine spec as follows
custom made forged rods
75mm forged pistons
billet crank
custom cams
custom valves and valve springs
uprated valve stem seals
athena head gasket
ported and polished head
and all appropriate machine work to go with it
skimming notching etc
new water oil pump and gasket set
lightweight pulley set and adjustable cam gear
possibly run it on coil pack instead of dizzy but we will see
@ anyone else what are peoples thoughts on colour choice at the moment im thinking candy apple red or ancharite grey
Got a fair bit done today just need to remove the steering rack and rear axle and then the cutting can begin, then i will be degrasing the whole car and then the sand blasting can be done, will be doing the inside outside and underside then i can start work on the cage
this was the design i had in mind any thoughts on it
