tersplat Posted January 27, 2011 Posted January 27, 2011 A common problem if you run an engine un-tuned is detonation(combustion before the piston is at Top dead center, caused by timing being too far advanced for the engine). Detonation causes a shockwave throughout the cylinder and the pressure escapes through the weakest point, which in the stock E-series engines is the piston's "ring lands" and breaks them. When you take the engine apart, you will only see a few tiny cracks on the side of the piston between the piston rings, but behind that wall, those cracks are connected, exposing the crankcase to the full onslaught of the cylinders pressure, which is going though tiny holes in the piston's lower oiling ringland. This can allow your fuel, and combustion gasses to enter your oil and break it down extremely fast, but no worries, as you will burn oil faster than the gasses can deteriorate it. The symptoms of this are:1: a rough idle, due to a cylinder misfiring.2: turbo oil seals being damaged due to excessive oil pressure3: oil coming out of your breather or catchcan filling up very fast4: oil vapors or smoke coming out of your breather, pcv valve, or any hole in your valve cover.5: exhaust sounds vaguely like a boxer engine.6: very low compression on one or more cylinders(190,190,190,120, or something like that)This video and these pictures will show you what to look for and how to diagnose these symptoms.here are the pictureshairline cracks:and once you remove the piston rings, you will find out that the cracks are connected.this is what you will find. You can slightly see the oiling holes I mentioned they are only about 1mm in diameter eachand the video. Excuse the squeaking, the radiator squakes due to a loose mount, but is being replaced while the engine is out.Well I hope that maybe someone is able to learn from this post, and that nobody ever has to deal with this problem. Quote
micky boy Posted January 27, 2011 Posted January 27, 2011 Awesome right up mate thanks for sharing Quote
yaristurbo Posted January 28, 2011 Posted January 28, 2011 brill mate loads of info, i hate the dreaded blow by causes far to many probs Quote
Sparky Posted January 28, 2011 Posted January 28, 2011 Nice little write up mate same happened to me (yet to strip my motor)But I will be stripping the new motor so at least I know what I am looking for now Quote
Russleh Posted January 28, 2011 Posted January 28, 2011 what would cause detonation on a tuned car. my old engine was setup on hks fcon and rolling roaded etc to 200bhp and i had that problem twice. but the car had run fine for ageeees before. when i built a whole new bottom end it happened again in about 6 months. is that likely to have been detonation or just maybe a bit to much hard drivin for standard pistons ? Quote
tersplat Posted January 28, 2011 Author Posted January 28, 2011 Could be a number of things. Could be bad gas, with a lower RON or possibly timing set wrong. Quote
jackellis19 Posted June 24, 2013 Posted June 24, 2013 ive done a compression test and its coming up with 100,100,60,100 i have all of these symptoms and am almost sure its a ringland would a replacement piston and new set of piston rings head gasket and head bolts solve this? im on the tightest budged possible and its my daily car, im sorry if im posting this in the wrong place i am new haha Quote
SmurfyBhoy Posted January 20, 2014 Posted January 20, 2014 My compression was 165 170 170 170 that okay ??? Quote
Taggy Posted January 20, 2014 Posted January 20, 2014 (edited) yeah thats good, as long as they are within 10% of each other its considered normal and a minimum of 150psi Edited January 20, 2014 by Taggy Quote
Sudden Posted June 29, 2016 Posted June 29, 2016 My compression is 262 251 258 261. I have blow by, I was wondering if not having the oem pcv setup would cause irregular crankcase breathing (trying to breath in and out through both crankcase vents simultaneously? Quote
