basically ive done everything else sept upgraded my manifold and bought hks actuator and braided oil feed just wanted to know weather or not its risky cranking the boost up without the other parts?
thanks
  • 3 months later...
Guest tubby_ep82
Anyone know if the stock clutch will take 1 bar on the ct9 hybrid ?
Regards
^My clutch slips at 0.8 bar on a CT9A so I'm looking to upgrade to a CAP Clutch
On topic, I run 0.7 bar on a standard mani that has been ported, I'm a bit hesitant to run 1 bar through it though!
dont start seying this i will be buying a hks actuator now! :(
anyone actually blown a piston doing this or is it just a rumor?
Can't u just port number 3 on the stock manifold?
Rob2.2 on here has it done on his stock manifold running 1.0 bar on a hybrid plus his cat is still fitted but is gutted and it's been on there for years now! And he drives it like a right nut
I've heard the stories about melting pistons many times it definitely happens I guess some people are just lucky if it hasn't happened to them bud...!
okay thanks for the input suppose it could come down to a few things at the end of the day.
Was round at Mark@CMB's the other day and there was a block sitting absolutely destroyed, young lad running circa .8bar on a standard manifold, flat out in 5th so probably creeping a bit too. Bang, mass destruction!
I wouldnt have a problem running one if it was ported but not with that massive restriction in the runner!
