drilling of carbon fibre bonnet for washer jets,
just wandered if drilling carbon fibre has any adverse affects like cracking or spliting
need to dril two washer jets into the bonnet for all this shit weather
from what I've heard its best to tape up the area then drill thru and apply a little superglue to the inside of the holes to ensure a seal then to let em dry before fitting washer jets
you be better off taking the bonnet off the car and drilling it from the under side, then if you do slip and scratch it who gives a fuck.
Or you could drill your washer jets into the scuttle panel?? But Si's method is the one I've heard from most places. You need to seal the inner plys well or they'll absorb water and seperate, super glue or epoxy resin.
That might be an interesting idea it would keep the nice clean smooooooth looks of the carbon bonnet. But still be practical
been lookin into these carbon bonnets lately because i have the money sittin here to buy one. but all the ones i looked at are just carbon layer over a fibreglass frame.
has anybody imported a proper one from japan or OZ or somewhere?
its ok scrap what i said. toby is selling them on tgtt....£520 + delivery.....bonnet vent is fuckin horrid though. wont be buying one of them.
Guest daveburwash
Dave, do your cf bonnets come pre drilled?
No they dont, has all the fittings on though
Thats the Varis one your on about bro. Its more expensive than the Carbon Culture one...
yeah but the varis is the only one thats a proper carbon fibre bonnet.
the carbon culture one is a carbon layer over a fibreglass frame.
not sure if you've already done this,
but I drilled the carbon bonnet on the mr2 to fit bonnet pins (very wise move) and had no prblems, metal bit went through it like a hot knife through butter.
Another point to make, is why not get the washer jets from a Pug 407 (I think it's that model) that sit on the wipers themselves...I have these on the 2 also and they look and work perfectly :p
thanx night spirit but im one step ahead of you,
found these on ebay from a company called storm that specialises in single wipers.
these only work out at 9 quid, problem solved, job done
im also gona get the smooth cases too
thanx for everyones input :p
i still have no washer jets and havent since i got the carbon bonnet. i may get wipers with washer jets built in or fit the washers on the plastic grill stuff at the back of the bonnet where the wipers are attached.
my boyfriend and his friend had to drill huge holes in my carbon bonnet for my bonnet pins! it was very scary! lol :p
yea must have been a harowing experience, you must have been wincing at every turn of the drill lol
happened to a mate, if it happened to me im sure id soil my boxers a wee bit especialy if it was at hi speed lol
