  • Replies 983
  • Created
  • Last Reply
Top Posters In This Topic
welll i never got my radiator fitted as i have now got more troubles than a leaking radiator :)
My car has been running a bit rough recently due to a leaking manifold ( stud out the block missing)
Had a friend of mine have a look for me and told me it could be 'pinking', for those who dont know its were the timing is advanced so the spark comes in before the piston reachs TDC.
So i had planned to take my car to a different friends house who was going to change my timing for me but he had broken his timing light so i thought well it cant be too bad, ran the car for a month and nothing has happened.
Was driving alone at 30 mph and the car decided to run on 3 cylinders "/, made a guess that it would be a spark plug that stopped working so i drove another 3-5 mins up the road to college.
Got the car to college and because im doing a motor vehicle course i got straight on the job of sorting it out, so i changed the plugs.. all worked but still ran on 3 cylinders, checked ht leads, all work and still ran on 3 cylinders so i did a compression test....
Oooops! cylinder 1: 0 bar, cylinder 2: 9.9 bar, cylinder 3: 10.1 bar, cylinder 4: 10.0 bar.
So i put a screwdriver down each bore to see if the piston was moving in cylinder 1, no movement :).
So i thought camshaft snapped or conrod, there is no hole in my block so didnt think it was conrod and the car runs so cant be camshaft.
Im guessing the conrod has either snapped at the bottom so it wont be touching anything just spinning or the bottom end shells have come apart.
Strip down commences then!
As some people may know that 4efte's manifolds are a pain to remove so took me ages removing them.
Inlet Manifold off:
Exhaust Manifold off:
Exhaust Manifold Gasket:
Looking worse for ware!
Checked the inside of my turbo and doesnt look to bad tbh but i honestly dont know what im suposed to look at.
Inside of my Inlet:
Dirty!
Quick Clean:
Will clean properly when refitted.
Outside of my Inlet:
Cleaned up a bit:
Decided since its going to be a while i might aswel make stuff not just go better but look better:
Prep.
Etch Primer:
Metalic Gunmetal Grey:
Condition of cams:
They dont look too bad but do look a bit scortched
Old Radiator:
New Radiator sat in place:
Sooo there is the start to a long horrible depressing winter... but atleast i know my engine will be fine when its back up and running again.
TBC.
sorry but i like them too much :)...if i do think to sell them then i PM will be coming your way :). cheers mate :)
Haha, they are lovely wheels. And cheers haha! I'm sure you'll get it sorted:) If you need a hand there's always plenty of help on here
D
looks very nice.
were the celica seats hard to fit?
Not really tbh :), they are sorta bodged onto starlet fails but they do fit and do recline etc so its all good, just the base of the seat only has 2 bolts in instead of 4 :)
Worth buying a set as i bought mine for a good price and they are super comfy.
Sounds like you ringlands on pot 1 have give up mine did I similar thing recently and I ended up needing 2 pistons.
You will need to get the head off and find out what numbers on the piston (mine were No.2)
You can get pistons from camskill and you'll need a headgasket and some sump sealer.
Mine cost me £65 to fix because I had spare pistons that also included a service timing belt and headgasket. And a few hour of work.
Thanks for that luke, i should get the head off tomorrow, only reason i havnt is because i need a h9 bit to remove the head :)
Thanks Zoe :), ahh its okayy i still have the Red N/A to run about in :)
Haha, i've like 3 H9 bits in my garage lol!
D
Cheers for rubbing it in haha :), can you clarify they are H9 bit needed to remove the head ? :)
Haha, sorry lol. I cant guarantee what size they are but I can promise i've got that size lol. IIRC they're a M9 Multi spline. Not to be confused with Torx
D
well thanks haha :), yeahh i think they are hex 9 multisplined :), looks like im going to have to get one from Halfrauds.
Priced one up today at a local Snap On dealer and it was about £15 just for the 3/8 H9 bit "/ !... No Thankyou!
Just for the bit? Not including the socket to hold it? Halfords trade card for the win:P I bought a full set for £20 lol
D
Lew: nahh still got it, a lass down my street owns one also, if you next see a red one check if it has a scoop or not :) if it has one its me, if not its not me :)
Starlet sr: with the socket too yeah but still expensive, hmm £20 sounds good as i have a trade card too :)
Tbh, thats not bad for a snapon item. And get yourself down lol
D
  • 3 weeks later...
Slight update,
Since the cars off the road ive thought to myself i might aswel concentrate on giving a bit of tlc with other bits and the engine is going to be a while yet so i lacquered my strut brace and inlet.
Alot better than it was before and before it still looked good.
Inlet
Another snap at the block (check out piston1...shiney due to hitting valves :) )
Close up
Piston on an angle
valves bent :(
And again
Cylinder 1's piston at the bottom without even turning the engine but just tapping the top of piston....Ooooooops!
Removed my wipers as i thought they were looking tired
More to come :p
  • 4 weeks later...
Been a while as the bad weather has come and not having the time to do anything but have a few little bits.
A little something that came in the post :)
On the n/a also
Needed a few bits removing so it was to a bare block, Alternator off which was filthy
Out.
Not Happy
Getting there
It'll do
