nazzurro19 Posted September 19, 2011 Posted September 19, 2011 who was it askin for poly cv bushes past week pm me if it was you !! Quote
lugzy clart Posted September 19, 2011 Posted September 19, 2011 i think 3 sets poped up last week n then everybody wanted them lol so your in box might get a lil busy haha Quote
LeeroyV Posted September 19, 2011 Posted September 19, 2011 i was but think i may have sourced some now... what you know then??? Quote
joel_ep91 Posted September 19, 2011 Posted September 19, 2011 calling mr badger, mr badger to this thread please Quote
nazzurro19 Posted September 19, 2011 Author Posted September 19, 2011 yeah ive found some for sale on another site but mr badger has dibbed them sorry guys Quote
lugzy clart Posted September 19, 2011 Posted September 19, 2011 how cum these things pop up every now n then yet no body nos where tho buy them from lol the only place ive heard is if your go to google australia bu wen i tryed no such luck lol Quote
Russleh Posted September 19, 2011 Posted September 19, 2011 did someone not write a review for them a while ago saying they split very easily ? Quote
lugzy clart Posted September 19, 2011 Posted September 19, 2011 Bu ain't socks got them on his car now ??? Quote
Starlet__SR Posted September 19, 2011 Posted September 19, 2011 In all fairness, best ones are the rubber pattern ones as they flex and dont crack, always coat mine with silicon grease to keep them in good nick and never once failed, genuine toyota and the poly ones crack and wear easy due to being very stiffD Quote
Socks Posted September 20, 2011 Posted September 20, 2011 In all fairness, best ones are the rubber pattern ones as they flex and dont crack, always coat mine with silicon grease to keep them in good nick and never once failed, genuine toyota and the poly ones crack and wear easy due to being very stiffDWrong...The poly ones are too thin, mine exploded and splattered grease everywhere within a week..Phil was after some because he'd tried everything else... I believe he has other problems causing his to fail like that though, must have :sThe genuine ones managed 40,000miles on my car in stock trim and believe me they are the best ones to get! Quote
Starlet__SR Posted September 20, 2011 Posted September 20, 2011 Wrong...The poly ones are too thin, mine exploded and splattered grease everywhere within a week..Phil was after some because he'd tried everything else... I believe he has other problems causing his to fail like that though, must have :sThe genuine ones managed 40,000miles on my car in stock trim and believe me they are the best ones to get!Wrong? I dont think so. Dependant on the manufacturer the quality varies, and when I ran a set I found they were too stiff, not enough flex in them. Same with the genuine ones. The rubber items are far better as they have the flex and elasticity. I've always used the rubber ones and never had one split that i've replaced yet, including dads almera which has covered 62000 miles in the time we've owned it. So in all fairness. far from wrong. Just different experiences:)D Quote
james@cjperformance Posted September 20, 2011 Posted September 20, 2011 i found poly boots would either split or pop off the joint due to being stiff. you can have poly boots made that are quite flexible but at the same time will not perish orv deteriorate like rubber will. Quote
Socks Posted September 20, 2011 Posted September 20, 2011 Wrong? I dont think so. Dependant on the manufacturer the quality varies, and when I ran a set I found they were too stiff, not enough flex in them. Same with the genuine ones. The rubber items are far better as they have the flex and elasticity. I've always used the rubber ones and never had one split that i've replaced yet, including dads almera which has covered 62000 miles in the time we've owned it. So in all fairness. far from wrong. Just different experiences:)DIm running a damn sight more power then you and the poly ones didnt last 2 mins. Ive had some soft and stiff ones... The OEM ones are by far the best ones.... Just make sure you dont overpack the grease... Quote
Starlet__SR Posted September 20, 2011 Posted September 20, 2011 Im running a damn sight more power then you and the poly ones didnt last 2 mins. Ive had some soft and stiff ones... The OEM ones are by far the best ones.... Just make sure you dont overpack the grease...For now;) But anyway, regardless of power, its everyday driving what kills the polys. I do alot of b road driving and tbh, the rubber ones have proved the most effective. The poly's are far too stiff, same with some OEM ones. Just depends on the brand and style of driving. QH are a favourite of mine. I ran a set on my LET corsa and never had one split. Ran those for 40k miles at 250-300. First set of OEM ones I used split after 2k miles due to being too stiff. Overpacking has never been an issue either. D Quote
rorenapier Posted September 20, 2011 Posted September 20, 2011 Boots dont split due to power... They only usualy split due to being well past it (condition wise) being to hard or the CV letting go and taking out the boot at the same time.Standard rubber ones are just fine. Quote
Nanglebadger Posted September 20, 2011 Posted September 20, 2011 having read this, im inclined to stay away from Polys now and probably just stay with original ones.cheers lads.Phil. Quote
