Right guys dropped my car off today to have the gearbox driveshaft oil seals relpaced, and got a call to say that my cv boots were ripped and totally fucked and that they needed to be replaced now the problem is the drivers one is totally seized and wont come out of the hub.
Has anyone had a similar issue and how did you get this sorted cars still at the garage now :(
hope my explanation kinda makes sense cheers for your help any recommendations how to get it out? there isn't any hidden clips or similar to remove it?
cheers james they said they might have to "remove the whole leg" and do what you said above but im guessing thats gonna get expensive? and im so skint, i hate this time of yr tax, mot, insurance all in the same month and now a giant repair bill
what kind of garage doesnt have a hub puller? it bolts on using the studs and a screw type device or hydralic pushes on the middle of the shaft. most garages have one. either that or get a copper mallet. that way you wont damage the threads on the end of the shaft.
right well EPIC FAIL the garage couldnt get the driveshaft out/unseized and today has cost me £210 and left with a broken car and have got mot this month "oh the joys"
if u heat it it will fuk wheel bearing, tell them to use an air chisel on it and it will be out in 2 secs
yeah they said heating would fuck up the wheel bearing cheers for the suggestion ill let them no lol
You could also remove the hub and use a hydraulic press to push out the shaft,
Soaking the parts usually helps alot but you don't want anything to strong as it will penetrate the bearing.
But copper mallet or press are the best options
Regards
Gary
Thanks Gary yer he said he would press it out, but that's gonna bump the price up a fair amount cause e will have to remove the whole leg etc it's just bollox man proper pissed off gonna take the car elsewhere me thinks
£210?? what work did you have done? Drive shaft seals and CV joints are easy 20 - 30min jobs.
removing the suspension leg shouldn't cost much more at all, four bolts at the top of suspension and three on track rod end. takes 5 mins.
if they are charging a lot extra for that go somewhere else.
Edited by 5T4R7ET N/A
i got charged 210 yesterday for:
change driveshaft seals on both side of the car
the left cv boot kit and fitting
fitting the zep braided clutch line
re fill gearbox with oil i suppled the oil and both driveshaft seals and obv the clutch line
charged with their attempt of removing the drive shaft on the right possibly?
but pissed of really gonna probably get this driveshaft seal done elsewere need a new garage now, sigh
sounds to me like you have been done over bud. hate garages like that. your prob talking less than a half days work there. maybe 2 hours at most. plus you have supplied parts so i would say around £70 at the most.
find a better garage/mechanic bud. if they struggled to get the driveshaft out then i would hate to see them attempt a engine or gearbox change.
Sorry to say, they ripped you off.
If i was you I would buy some tools and do the work yourself. save yourself and fortune and learn a lot about basic repairs.
plenty of folk on the forum will help you out.
What a fucking rip off :/... When I worked in a garage even with all the tools etc, if I came across a seized driveshaft for example, all I'd do is brush down where I can with a wirebrush, use a bit of wd40 and smack the shit out of it with a copper mallet.... It always worked lol.... If need be just heat it up and replace the bearing. Fuck paying them for not even finishing the job though. That sucks!
Edited by aaddzz123
  • 2 weeks later...
last week i ended up taking the car to my work mates brother, hes got a mk1 escort (mexico rep) in lime green running a 200sx engine which he done all the work on himself running some big power even has jun cams lol,
anyway:
yer took it to him old school garage= old school prices. He got it out but he said in 30 yrs of mechanics hes never seen a driveshaft seized so bad. He used this ancient looking hydraulic press to get it out and charged me a very reasonable £68 and changed the altenator/water pump belt as he noticed a nip in it.
