FreedomCore Posted April 30, 2012 Posted April 30, 2012 How the hell do I undo these things?There is a somewhat annoying rattle and ive tracked it down this the trim. Just cant open it. The "screws" just seem to keep turning.fml Quote
akyakapotter Posted April 30, 2012 Posted April 30, 2012 There a bastard I used an o ring pick :-) Quote
Banbury Glanza Posted April 30, 2012 Posted April 30, 2012 Got the same problem I sured double sided tape under it as a temp fix lol Quote
FreedomCore Posted April 30, 2012 Author Posted April 30, 2012 Always resorting to snapping things. Knowing me, ill integrate cable ties into the fix.God Bless Cable ties.But seriously wtf are these things, Why make them appear to undo if they don't. Quote
akyakapotter Posted April 30, 2012 Posted April 30, 2012 they do undo but you have to be very gental with them Quote
FreedomCore Posted April 30, 2012 Author Posted April 30, 2012 Well ill give it another whack tomorrow after work and ill let you know how i get one. Ill try your gentle approach. Quote
DaveyDemolition Posted April 30, 2012 Posted April 30, 2012 I was there for about 10 minutes unscrewing and pulling and pushing, got bored and ripped the whole thing out, i was going for the stripped out look anyway... Quote
FreedomCore Posted May 1, 2012 Author Posted May 1, 2012 Lol im going for that "I know what im doing look".Right now im failing. Quote
lew777 Posted May 1, 2012 Posted May 1, 2012 On the gt I just ripped mine off then when you put the trim back on just whack them back in with your hand Quote
StuDoc 72 Posted May 1, 2012 Posted May 1, 2012 LMAO cmon boys Right what you do is get a star screw driver and the tiniest plain screwdriver you can find. Put the plain in the gap between the screw and the collar as if your going to pry it out then gently ofcourse then use the star just to turn the screw while gently prying it out. Once you have it unscrewed use the plain to pop the whole thing off the plastic. Peace of piss ;) Quote
FreedomCore Posted May 1, 2012 Author Posted May 1, 2012 I wish they just used standard screws. Cheers for the pointers though. Ill give it a whack later.That rattle wont get the best of me!I think i heard the belt rubbing this morning. =/ Quote
StuDoc 72 Posted May 1, 2012 Posted May 1, 2012 Trust me buddy thats the way to do it. Years as a mechanic thats ive done a billion of those lol. and as for the rattle get urself plenty of tape and use that to make things a tighter fit ;) Quote
FreedomCore Posted May 1, 2012 Author Posted May 1, 2012 Ive always prefered to cable tie it to death. But we shall see what the occasion calls for. Quote
WallaceGlanza Posted May 1, 2012 Posted May 1, 2012 The rattle can be sorted by wrapping the hinge mechanism hook in some fabric to tighten it up there, that's what I've done. On newer/posher cars they don't have a bare metal hinge catch as it does rattle. Quote
metalmickey0 Posted May 1, 2012 Posted May 1, 2012 I had that rattling too, found it was the panel vibrating on the lid. I now have no screws holding it on either.I used stick on velcro instead now of screws. Keeps it quiet and you can rip it off again if needed. Quote
FreedomCore Posted May 2, 2012 Author Posted May 2, 2012 Dammit. Didnt work. Just smooshed the screw head =/ Quote
metalmickey0 Posted May 2, 2012 Posted May 2, 2012 Dammit. Didnt work. Just smooshed the screw head =/As the Borg say `Resistance is futile`. Give it another bash, if in doubt get a pair of side cutters and attack them as they only plastic Quote
FreedomCore Posted May 2, 2012 Author Posted May 2, 2012 Well ive got a few days off work so ive got some free time. May tomorrow will be my day.Confidence Boosted - Mission Complete Quote
R34GTt Posted May 2, 2012 Posted May 2, 2012 You have to hold the outside of the clip to stop it spinning with the centre screw and turn the screw without putting too much pressure on it. The key to success is a correct fitting posi-drive screwdriver and not much pressure. Quote
Vincent-ep91 Posted May 2, 2012 Posted May 2, 2012 I used a flat head screw driver to stop the outer bit rotating. Then use a philips head to screw the centre out.Except the flat head slipped and marked my booth door Quote
craig-glanzaEP91 Posted May 2, 2012 Posted May 2, 2012 get a little flat head screwdriver and prise it in behind then just pull the screwdriver out towards you n theyll pop out no probs sometimes all you needto do is unscrew them , but as the plastic is soft as f*ck the threads are always gone on them so you are unable to unscrew them , either that or if you have a pick set get a right angled pick and just do the same as you would with the screwdriver , they should come out no problem , sometimes youv just got to see where they land as they fly everywhere lol ! Quote
ryan lang Posted May 3, 2012 Posted May 3, 2012 i did a mint diagram on how to undo these somewhere Quote
