JTStarlet92 Posted June 7, 2013 Posted June 7, 2013 Keep an eye on Japspeed systems from 2fast2cool on eBay. I pick mine up for £60.00 plus postage will take a bit of cutting a welding, but a good system for the money. Plus I'm sure you could flog the back box and getting another one.I got mine from here for £70 posted, then another £160 to Dean@RW for a custom exhaust mani yet to be fitted though Quote
Chris Green Posted June 7, 2013 Posted June 7, 2013 I got mine from here for £70 posted, then another £160 to Dean@RW for a custom exhaust mani yet to be fitted though Ah, Thats your tidy black manifold which was on Dean's FB page. Looks awesome dude! Quote
FreedomCore Posted June 7, 2013 Author Posted June 7, 2013 Ah, Thats your tidy black manifold which was on Dean's FB page. Looks awesome dude! I just saw that. Now that i wouldnt mind! Quote
JTStarlet92 Posted June 8, 2013 Posted June 8, 2013 Yeah, its mild steel so was relatively cheap! Top quality work like! Its fully heatwrapped now, can't wait to see the gains! Quote
jimmymac101 Posted June 15, 2013 Posted June 15, 2013 Your be find boss don't stress, I passed an mot with 122k on the clock dodgy temp sensor at the time aswell You should have no problems James Quote
FreedomCore Posted June 15, 2013 Author Posted June 15, 2013 Passed. They undid my JDM rear lights worrying though. What should I do. Put it back and sort a fog light out. Or just put it back. Quote
morgey Posted June 15, 2013 Posted June 15, 2013 Sweet!!Get a second twin fillament bulb holder and put a fog light in the lower right rear light. Thats what I've done Quote
Flynn Posted June 15, 2013 Posted June 15, 2013 Put it back and worry about them this time next year! Quote
Matts Posted June 15, 2013 Posted June 15, 2013 Mine also passed today straight away no problems, do what i always do when doing the conversion! get a twin filament holder and wire that in for the jdm bottom sidelight and fog works a treat and passes mot! Quote
dan106 Posted June 16, 2013 Posted June 16, 2013 What do you guys mean by jdm rear light wiring? Quote
FreedomCore Posted June 16, 2013 Author Posted June 16, 2013 What do you guys mean by jdm rear light wiring?It's when the you have like 4 rear lights rather than 2. There is a tutorial on the how to section. Easy job. Quote
morgey Posted June 16, 2013 Posted June 16, 2013 Need to get a glanza left rear light as uk has the reverse light, you ditch that and have tail lights top and bottom and brake at the top Quote
Xpect Posted June 16, 2013 Posted June 16, 2013 A European left light is fine too. But really I like the twin white fields more. That's when you get a right rear light from a LHD car. Quote
FreedomCore Posted June 16, 2013 Author Posted June 16, 2013 A European left light is fine too. But really I like the twin white fields more. That's when you get a right rear light from a LHD car.Ive never seen that done. Any pics? Sweet!!Get a second twin fillament bulb holder and put a fog light in the lower right rear light. Thats what I've doneHow do i go about doing this? Quote
morgey Posted June 16, 2013 Posted June 16, 2013 Scrappy or someone breaking there car. Just need another top bulb holder with a few inches of wire, they screw into the bottom the same as the top. Wire it up pop a bulb in the same as the top (something like 5w/55w) or with a higher wattage than the brake light so the fog light is nice and bright and hey presto Just make sure all the tail light wattages match or your'll have some brighter than others lol Quote
FreedomCore Posted June 16, 2013 Author Posted June 16, 2013 Scrappy or someone breaking there car. Just need another top bulb holder with a few inches of wire, they screw into the bottom the same as the top. Wire it up pop a bulb in the same as the top (something like 5w/55w) or with a higher wattage than the brake light so the fog light is nice and bright and hey presto Just make sure all the tail light wattages match or your'll have some brighter than others lolSimple as that is it? It's going to turn out simple, but i just dont get it =[ Quote
loguey Posted June 16, 2013 Posted June 16, 2013 And if your feeling super lazy. Scotch locks will be your friends... Quote
FreedomCore Posted June 16, 2013 Author Posted June 16, 2013 And if your feeling super lazy. Scotch locks will be your friends...Lol i don't mind doing it. I just like pictures and like bullet points. Quote
Matts Posted June 17, 2013 Posted June 17, 2013 Lol i don't mind doing it. I just like pictures and like bullet points.1) Goto scrap yard or breakers online and ask for a twin filament bulb holder which is used for the rear brake and side light.2) Remove the original fog light bulb holder and cut the wire.3) Using the new twin filament bulb holder wire the original fog light live wire to the high filament wire that's coming from the holder and then bring a wire down from your top sidelight and wire that into the low filament wire coming from the holder and then connect the earth also.4) Insert a top and tail twin filament bulb into the holder think its like morgey said (low filament is 5w and high filament is 55w) basically a brake light bulb.5) When sidelight is on the low filament should light up that being 5w and when fog light is switched on the high filament should light up that being 55w.That's what i do like many others its really simple and does pass the mot Quote
dan106 Posted June 17, 2013 Posted June 17, 2013 Ahhm I see! What does it look like on an n/a outta interest? Might have to give it a go Quote
morgey Posted June 18, 2013 Posted June 18, 2013 (edited) Bit of a blurry picture but looks like this Edited June 18, 2013 by morgey Quote
