I'm slowly gathering the mods to aim for 1 bar my ct9, now I really am worried about cutting out my bumper as although i love the widemouthed look, i'm a bit OCD and couldnt do with it unless it was smoothed and cut perfectly?
So just wondering, is an ARC TMIC suitable to run 1 bar at or would i need an FMIC, and which option is recommended?
  • Replies 69
  • Created
  • Last Reply
Top Posters In This Topic
fmic would be better, get a good kit tho.....like the wepr/zisco one
starlets dont need massive coolers total overkill imo a small well placed cooler is where its at
I have an ARC top mount at 0.8 bar (upping to a bar soon) and its perfect, instant boost. Dont need a fmic if your still running the ct9 IMO. I can rag my car like fuck for however long I want, park up and put my hand on the intercooler and it will be stone cold. one of the best mods I've done to the car ( relocating air filter was a close second).
ARC's are worth the money but for the same price you can get a FMIC i know what one id choose :) the inlet temps on a fmic would be alot cooler then the arc someone on TGTT tested the inlet temp's on a ARC runnig 1bar of boost and they were realy high he said they where that high he couldnt understand how the engine could cope with that much heat!!!...Think it was Tim for TB developments (toyota specialist) that tested the inlet temps ill try and find it.
Hmm let the debate begin. "you can't up boost without a front mount." inlet temps may be a bit higher but the lag is 100% less. I've never ever had a problem with heat soak etc. makes me laugh how the big opinions come from people have never even tried an arc top mount lol :)
^Interesting!
I'd go with FMIC, it's future proof in case you decided to go for a bigger turbo..and they look HENCH lol
Edited by Amjad
I loved the ARC on my car because of that very reason "quick spool" after all thats what these cars are about power to weight quick spool ect but to be honest if you get the sort route pipeing for a FMIC thers not much diffrance in spool up times and the inlet temps are way cooler so you've got the best of both worlds..An ARC intercooler is good if you want to keep your car a sleeper but other then that it will never be as good as a FMIC thats my though anyway lol
If you're going for a bigger turbo, go front mount. If you're staying ct9, arc or rx7 top mout. I hate having this debate with people, there are pro's and cons for both. I'll be going fmic when I go td04 but until then my arc is worth it's weight in gold.
the only thing i noticed when i changed to my hdi fmic (a massive core) was the change in noise from the turbo :) there was no change in spool what so ever
plus you have the added bonus of the looks and if you were ever to upgrade the turbo you wouldn't have to waste time faffing as an fmic you already be in place
^Ditto
Emptied it now sorry :/
Amjad, that's exactly it, an fmic sticking out of a neatly cut bumper looks rude as fuck
My dilemma is a front mount is better in looks, performance and sound, my only worry is cutting the bumper and getting it and my optional lip to look nice without smoothing and tea praying, any tips?
Here's the thread Mickey was talking about, post #38 :)
http://www.toyotagtturbo.com/forums/showthread.php?74284-something-interesting-and-concerning-about-the-stock-intercooler/page2&highlight=intercooler
To be honest you probably do need to be careful cutting the bumper but if you mount the core right it's not too bad. I had to get mine sprayed but that's because it had some damage on it anyway. Totally future proof mod, and you mentioned the looks ;)
Rule of thumb is for every 1 degree the inlet temp drops you get an extra 1 bhp.
Like charl said its up to how you want your car to drive. Quick spool get a arc. For those who say just go front mount, try driving charls advance. Its a completely different animal with that arc. Nothing like the standard tmic.
Both have pro's and con's. Some cars in the states that are running silly quater miles don't even run a cooler of any type.
i run a top mounted rx7 intercooler at 1 bar on a toy tuning ct9 hybrid and i have no problems at present, but i do totally see why a fmic would be better but its just purely the butchering of the front bumper is my one and only reason to not go fmic !
Any measured temp differences? Cool to the touch means sweet f all...
Any one got any figures of how much quicker boost comes on with an arc? Ie 200revs etc?
No one has to butcher the bumper ^ using a massive core is pointless get a smaller core and your done
Edited by Asad
Agree
and there is no diffrance what so ever in spool up time if you get the sort pipeing and a small core intercooler you will love it!! But also you can think at the back of your mind when you are giveing it big licks that its getting enough cold air and isnt trapped under the bonnet getting heated up!
Ohh and thanks Amjad i couldnt find the thread!
Edited by micky boy
Arc tmic is cool, it's a bit different and I managed to get 190 bhp on one with the oem ct9 , I would love to see how a td04 ran with one that would be interesting
Oh yeah to add when I swapped the arc for a fmic I made 200 so a clear 10 bhp and that was at same boost with everything else the same what I noticed was more of a pull at higher Rpm but obv a lot more lag
Amjad that red Glanza looks sick, well they all do but it's the nearest to how mine would look except I've got the oem 98 spec lip as well, I think cutting the bumper would be easy it's the splitter that will be hard as it has the cut out section for the plate?
When you say a smaller core are you tralking along the lines of this size ?
Core size: 540mm x 140mm x 65mm
would it be possible to fit this without any cutting of the bumper and no moving of the reg plate ?
Edited by russ78
