So one of my mates had an Audi A3 1.6 with a broken gearbox that he picked up for pennies (he was originally going to break it for spares), he got offered a swap for a glanza
warning, this is a bit of a rutter
its had a bit of love at some point with a nurspec exhaust, d2s, nardi wheel and a few other bits
Im guessing it had a front exhaust at some point too:
So the idea for this is get power, without a lot of money. keep it looking like a dog, and suprise quite a few people
so the civic rad went on:
The fpr was cable tied on:
The boost guage was connected and wired in:
And the rest of the kit, bought for £160, bargain:
So pretty soon there should be a good 200bhp or just over. costing him well under a grand! Bargain!
Its a build of bodges, as his main concern is not to spend a lot of money.
But its going well so far! will provide more updates as we get going
Edited by TrisK
  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
Wow! That kit was cheap! :o
cheap is the main factor for what we can do.
he did have to buy all the gaskets and lines from ricky and i think that came to about the same tbh! but still should be a good run
do people remeber where you could get japspeed exhaust for really cheap from?
can anyone post up the link?
The car is a bit rough, with the whole in the bumper, the mismatching door and general laquer peel.
but its a glanza none the less, and therefore deserves a bit of love
To be fair - she surprised me, she made 155horse at the fly running 0.6bar when i took her to get dynoed last month O.o and i cant actually figure out how in my mind, theres no boost leaks so the ct9 must be ruined, rather large cracks in the wastegate perhaps? perfect excuse to td04 it though ;)
The car is a true trooper I have been witness to that car surprising many other unsuspecting drivers on several occasions can't wait to see it when it's done i need to get a move on with mine lol
Ok so a few updates on this:
Car had a broken passenger drive shaft, so bought a new on from Iddy
Fitted it up and had a small issue
It snapped the new shaft in about 5 minutes of driving
So will got to rebuilding one working shaft from the two broken ones
And we managed to bodge an outer cv joint over an inner. So we had a working shaft
We then noticed that the rear engine mount was broken (why it kept breaking shafts) so that got taken off and welded. And is back together and on. And once again she drove herself down the road
Next the td04 kit got put on. Only a few photos this time. As by now we were fighting the light
And now it's all bolted on and working. Just need to do some adjustment to the actuator to actually make it boost
As its spun all the way out. And only makes a few psi. Can't hear any leaks or anything though :/
Also does anyone recognise the manifold design? What brand is it?
Also had the joy of not many more polybushed mounts
And a white line antiroll bar
Win!
Win!
We've compared a few images of a toyo with my own, but theres a few noticeable differences - so who knows - and as tris missed it - I'll point out that the brake lines were also discovered to be braided :)
Too right :) just been turning up the boost today but not going too extreme, wanna make sure the mount holds and need new boots on the driveshaft - as they're seeping a tiny bit of grease though nothing to worry about for the amount :)
It's at 0.6 currently which is a vast improvement on the 0.6 that I was running at on the ct9 (had a bad boost leak that I hadn't located in the inter cooler hardpiping - precariously covered by the previous owner) but she'll be wound up to 0.8 and eventually a bar when I get round to coming across to the uk mainland to have her mapped which should be in September just before JAE :D
You'll enjoy the td04 mate :) worth it for sure :)
Guess I should do a future plans list though :)
Fit new discs and pads
Adjustable panard rod
Rear anti roll bar
550cc injectors
Exedy clutch
Emanage blue
Mapping.
That should be enough to keep me going until JAE ;) at which point she will be mapped (as I need to travel to uk mainland for mapping :/ )
Rear anti roll bar
550cc injectors
Exedy clutch
Emanage blue
Mapping.
rear arb you will love makes such a difference ajustable panhard rod i have one to fit lol got some good plans for it mate good luck ;)
550cc injectors wont work with emanage blue. but you dont need 550's anyway from what ive read its just overkill.
ill be using less on a td05, probs 440/460's whatever i get hold of.
i have an emanage blue by the way that i can sell you. pm me if your interested.
cheers
Edited by snails ep91
cheers
It seems I've been looking in the wrong place for advice on the injectors, though I'd looked them up before I joined the forum so there we go lol - recommend a size? And I'll PM you when I'm not actually at work haha.
yer emanage blue cant handle fueelling injectors that big. 440cc injectors on standard engine with emanage blue on td04 would be a good setup i reckon.
yer fire me a pm when you want.
sam
