StuDoc 72 Posted May 31, 2012 Share Posted May 31, 2012 Alright guys going to be upping my boost in the next month or so. So been wondering with a standard CT9 whats the max pressure and the best optimum pressure to run them at. And is adjusting the actuator and physically boosting it and looking at the boost guage the only way to tell your pressure? I will be running a mani, decat, hks actuator, plug and play ecu, hks mushrrom filter, blitz nurspec r exhaust and an arc tmic.Cheers in advance Quote Link to post Share on other sites
TrisK Posted May 31, 2012 Share Posted May 31, 2012 Above 1.1/1.2 you won't be able to cool it quick enoughAnd the ct9 is out of its efficiency rangeI'd say 1 bar is your best bet Quote Link to post Share on other sites
StuDoc 72 Posted May 31, 2012 Author Share Posted May 31, 2012 Aye mate i was thinking about around 1 or 1.1 is setting it and road testing the only way to set it correctly? Quote Link to post Share on other sites
mattyD Posted May 31, 2012 Share Posted May 31, 2012 (edited) as said, anything above 1 bar puts the turbo out of its efficency range and the poor little thing begins to run out of puff Edited May 31, 2012 by mattyD Quote Link to post Share on other sites
Socks Posted May 31, 2012 Share Posted May 31, 2012 1bar is considered the limit...Few... including me run 1.2bar... but gains will be minimal! Quote Link to post Share on other sites
StuDoc 72 Posted May 31, 2012 Author Share Posted May 31, 2012 Im looking for between 170-200 bhp. What are these gains like over stock? Id imagine its quite a noticable difference? Quote Link to post Share on other sites
akyakapotter Posted May 31, 2012 Share Posted May 31, 2012 I run 1bar you will notice a considerable difference over stock boost Quote Link to post Share on other sites
Flaminsam Posted May 31, 2012 Share Posted May 31, 2012 Ask pick1 what boost he is running. I do believe it is about 1.8bar on a standard ct9? I've driven his car and it is really nippy. Quote Link to post Share on other sites
akyakapotter Posted May 31, 2012 Share Posted May 31, 2012 On 5/31/2012 at 4:12 PM, Flaminsam said: Ask pick1 what boost he is running. I do believe it is about 1.8bar on a standard ct9? I've driven his car and it is really nippy.1.8 wtf I could do that with my boost controller but I'm to scared to lol Quote Link to post Share on other sites
Starbo Moorley Posted May 31, 2012 Share Posted May 31, 2012 When i changed my ct9 cause the seals were shot i swapped my actuator on to the new ct9, went and ran it and it boosted too over 20psi but i let off when i noticed it ! it pulled like a bloody train haha, But as already said 1 bar but sometimes they they can take more ! Personaly id get shot of the plug and play and get emb so its mapped properly as plug and plays can.be a bit unpredictable, but of your stayin plug and play make sure you get your AFR checjed out Quote Link to post Share on other sites
pick1 Posted May 31, 2012 Share Posted May 31, 2012 Flamingsam is right I don't normaly get involved in these convos cuz everyone normally jumps down my throat I ran 1.8 for over two years admittedly not on purpose to begin with (vast boost creep)And yes higher up the revs it did start to drop off power like all ct9's but the acceleration was immense as like most ct9's hit full boost at like 3k rpm and my car still runs beautifully even now and just had a td04 fitted and the ct9 was bang on when me and mike had a quick look at it at tuning developments when Sam drove it it was at 1.4 and still very nippy Quote Link to post Share on other sites
Liam_D Posted May 31, 2012 Share Posted May 31, 2012 1.1/1.2 bar is maximum i know of anyone succesfully running a CT9 on. Quote Link to post Share on other sites
StuDoc 72 Posted June 1, 2012 Author Share Posted June 1, 2012 Whats the script with getting an EMB instead of a plug and play? Apart from getting them mapped. Whats the differences price wise? Id def be buyin 2nd hand on here. Do u need to wire in an EMB as in break into other wires? Quote Link to post Share on other sites
pick1 Posted June 1, 2012 Share Posted June 1, 2012 Yes mate it will all av to be wired in properly and the benefits are u can set the fueling up to be exact with with what ever set up u have so the car will perform and run better and make greater progress power wise etc I have emb and think its sound never had a problem with it as of yet Quote Link to post Share on other sites
StuDoc 72 Posted June 1, 2012 Author Share Posted June 1, 2012 So how hard are they to wire in and where do you wire them to? Do they replace the std ECU or is it a piggyback unit? What are the options and how much do they tend to cost 2nd hand? Quote Link to post Share on other sites
TrisK Posted June 1, 2012 Share Posted June 1, 2012 Are you sure you mean 1.8bar and not 18psi? Quote Link to post Share on other sites
Flaminsam Posted June 1, 2012 Share Posted June 1, 2012 Yup 1.8bar. Its turned down now to 1.4. Or it was when I drove it. Quote Link to post Share on other sites
AdamB Posted June 1, 2012 Share Posted June 1, 2012 If you want more efficiency, run a water injection system before the turbo to cool the air even further ;) Quote Link to post Share on other sites
pick1 Posted June 2, 2012 Share Posted June 2, 2012 On 6/1/2012 at 10:41 AM, TrisK said: Are you sure you mean 1.8bar and not 18psi?Yes mate 1.8 bar was running that for over two years and Sam is correct it was running1.4 when he drove it 😜 Quote Link to post Share on other sites
Max9650 Posted June 2, 2012 Share Posted June 2, 2012 On 5/31/2012 at 4:50 PM, pick1 said: Flamingsam is right I don't normaly get involved in these convos cuz everyone normally jumps down my throat I ran 1.8 for over two years admittedly not on purpose to begin with (vast boost creep)And yes higher up the revs it did start to drop off power like all ct9's but the acceleration was immense as like most ct9's hit full boost at like 3k rpm and my car still runs beautifully even now and just had a td04 fitted and the ct9 was bang on when me and mike had a quick look at it at tuning developments when Sam drove it it was at 1.4 and still very nippywhat power were you getting from 1.8bar? Quote Link to post Share on other sites
akyakapotter Posted June 3, 2012 Share Posted June 3, 2012 On 6/2/2012 at 10:44 PM, pick1 said: Yes mate 1.8 bar was running that for over two years and Sam is correct it was running1.4 when he drove it 😜How did it not shit it's self lol Quote Link to post Share on other sites
_shaun_ Posted June 3, 2012 Share Posted June 3, 2012 On 6/1/2012 at 10:11 AM, StuDoc 72 said: So how hard are they to wire in and where do you wire them to? Do they replace the std ECU or is it a piggyback unit? What are the options and how much do they tend to cost 2nd hand?they are simple to wire in if your good with a soldering iron you just wire it in to the loom before it connects to the ecu. you can get a field harness which will set u back about £100 and u wire it into there and then that plugs in between the standard ecu and the cars loom id recommend one if u went down the emu route as it has alot more wires but with the emb there isnt as many so prob not worth the extra cost.not sure what e-manage blues sell for second hand but if u fancy a trip to kilmarnock the guys that mapped mine are up there and i reakon would prob set u back about £200 quid to get it fitted and mapped main advantages of a piggyback over a plug and play is the piggyback while be maped to your exact mods and should pull a nice bit more power.a long with this you should find it better on fuel aswell because plug and plays have a tendency to overfuel for safety. however plug and plays hold there value i paid £500 when i had my blitz access and sold it for £500 bout 8 months later however if i was to sell my emu now id make back what i paid for the unit itself but the cost of mapping would be lost as the buyer would have to have it mapped for there specific set-up. Quote Link to post Share on other sites
pick1 Posted June 3, 2012 Share Posted June 3, 2012 Max950 I don't know if I'm honest mate it was mapped by td years ago when I first set the car up and at that time there wasn't a rolling road , so I never put it on one And I dunno why it never shit itself as I've always wondered that but I just looked after the engineServices it every 8-10 weeks when I was using it daily and just generally maintained it like I say just fitted tdo4 2weeks ago n my mate that works at vauxhall did me a compression test before fitting said my reading where still very good Quote Link to post Share on other sites
2333ricky Posted June 7, 2012 Share Posted June 7, 2012 my old glanza peaked 1.7bar and held 1.5 for few weeks and never had trouble with engine or turbo. but did it go at that boost.maybe i was just lucky. Quote Link to post Share on other sites
akyakapotter Posted June 7, 2012 Share Posted June 7, 2012 i really wanna try this now lol Quote Link to post Share on other sites
