LukeSR Posted June 29, 2012 Posted June 29, 2012 The SR failed MOT on a nearside ball joint, how hard are they to change? Quote
EliteMilk Posted June 29, 2012 Posted June 29, 2012 Easy mate 3 nuts knock it down with a hammer New 1 on SORTED :-)Easy mate 3 nuts knock it down with a hammer New 1 on SORTED :-) Quote
LukeSR Posted June 29, 2012 Author Posted June 29, 2012 Sweet, just ringing round now to see if anyone has one! Quote
LukeSR Posted June 29, 2012 Author Posted June 29, 2012 Got one coming in the morning from the local factors Quote
rob_bower Posted June 29, 2012 Posted June 29, 2012 Yea there pretty self explanatory and easy. Quote
WallaceGlanza Posted June 29, 2012 Posted June 29, 2012 Might need a pickle fork if they're tight to help ease (bash) them out. Quote
shorty Posted June 29, 2012 Posted June 29, 2012 Forks are shite tbh bent a couple of em. get a decent spliter with the winding bolt on if the are stiff will have it off in no time ;) Quote
daniel_g Posted June 29, 2012 Posted June 29, 2012 Big pry bar (like 3ft), hammer and plenty of wd40. Sorted. Quote
rob_bower Posted June 29, 2012 Posted June 29, 2012 both mine popped out with a bash from a malet. Quote
LukeSR Posted June 29, 2012 Author Posted June 29, 2012 Sweet Knowing mine though they will be a bitch to get out! Quote
Starlet__SR Posted June 29, 2012 Posted June 29, 2012 Absolute doddle to change. Just try and get some release fluid on the nut/taper.Day Quote
Flaminsam Posted June 29, 2012 Posted June 29, 2012 I crack them with a hammer. Hit them in the correct place and the shock will dislodge even the most stubborn ball joints. Quote
funny onion Posted June 29, 2012 Posted June 29, 2012 Apart from on my old clio, god himself could not remove it! Quote
LukeSR Posted June 29, 2012 Author Posted June 29, 2012 Cheers boys and girls.. If I have a problem you will all soon know Quote
rinseep82 Posted June 29, 2012 Posted June 29, 2012 Should b a quick job dude the top but may b a bastard if the ball joints are really worn when u try and loosen the top nut from where the ball joint goes through the hub it may just spin so u can either clamp the ball joint with some mole grips and a bit of heat on the nut or just do what I do and bang out the grinder and go to town on it haha Quote
akyakapotter Posted June 30, 2012 Posted June 30, 2012 Ball joint splitter I have 2 as im greedy lol Quote
jtaylor1990 Posted June 30, 2012 Posted June 30, 2012 Piece of piss dude, I cant remember but the ball joint may have a split pin to get out too, make sure u remove that carefully because u may not get a new one with the new kit, but I could be wrong about them havin split pins.A fuck off mallet should do the job though as previously stated Quote
rinseep82 Posted June 30, 2012 Posted June 30, 2012 Some have split pins some don't just depends Quote
LukeSR Posted June 30, 2012 Author Posted June 30, 2012 Well went to pick it up and they can't find it.. The probably didn't even order it the useless twats! Quote
