Changing Front Ball Joints
Should b a quick job dude the top but may b a bastard if the ball joints are really worn when u try and loosen the top nut from where the ball joint goes through the hub it may just spin so u can either clamp the ball joint with some mole grips and a bit of heat on the nut or just do what I do and bang out the grinder and go to town on it haha :D
Piece of piss dude, I cant remember but the ball joint may have a split pin to get out too, make sure u remove that carefully because u may not get a new one with the new kit, but I could be wrong about them havin split pins.A fuck off mallet should do the job though as previously stated :)
