Well im looking at getting all the daft things fixed atm, next on the list is to sort out the rev counter and install the temp sensor for the water, then i should be done engine wise:)
I'm going to fit my harness and look for a helmet then take it to teeside track for a blast round! just need to turn the boost down
Think im going to enjoy driving it for a while :)
Really im after some oem lips front and rear to finish the outside off
Good luck with moving in, you may as well be married now :p
Edited by Broony
  • Replies 149
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
  • 2 weeks later...
Looking good buddy :)
Cheers
Mike Jones
Tuning Developments Ltd
Cheers mate, solved the oil leak, it was the sump and oil pump seals.
Peter
New Recaro fitted, just need to make a rail for the passenger.
The most scary part of fitting this was modding the Bride rail as the Recaros have a low under carrage, but its all sorted and welded up:)
Recaro looks great in there dude!
Cheers fella,
My Bride holds better though:( if i couild of found anouther bride for the passenger for reasonable money i would of kept it but i was sick of having front seat that didnt match .
Well hopefully i have fixed my oil leak issues, after having the sum, oil pump seals and crank seals changed fresh oil and filter oil was still weeping from my engine, turns out it was leaking from the Dizzy, so for the sume of 6.48 GBP i replaced the seal on the dizzy and just as well:
It was hard and brittle.
  • 4 weeks later...
Few updates i need to add:
Installed new rocker cover and catch can
fitted HKS SSQV
All fitted just awaiting on the silicon hose to come so i can get rid of that dump valve and tee:)
I had some jam stickers made up:
Detailed the car :)
I think thats it :)
Cool, i would like a black one if that could be done.
Do you have Facebook? we can do it off UKSO if you like to prevent any trading issues?
update again!! Spending way to much money on this thing!!
Lets get lippy, Also straigtened my exhaust as it was hanging to the right ;)
Jam scoop Blank
Handling mods :) Anti lift kit and polbushed lower arms just need front anti roll bar polybushes
148426_10152279879030313_1326598363_n.jp
Edited by Broony
loving the updates mate :) scoop blank looks spot on :thumbsup:
and where did you get your rocker done? :p
Cheers mate!
Local fabricators up near me, charged me £20 :) then its all about loosing your finger prints :)
  • 5 months later...
