Kool thanks mate where the best place to shop for 1?
Find a good used one will be your best bet, otherwise RHDjapan might still sell them. But whatever clutch you use when going big on power, you will compromise the driveability.
its a forged 5e going to have all supporting mods running a td04 to start with in proses of getting crank balanced got flywheel just need clutch pulley looking to run a reliable 300bhp hopefully for a diy build just unsure of the clutch to run dont really wont a lumpy clutch for traffic would like best of both ish if possible was looking at helix or exedy from camskill not to sure if i wont paddle or fast road?
I've got a Helix, great clutch just slightly heavier pedal then the Exedy. Really good in traffic and no judder etc when pulling away.
is that a paddle or fast road thanks?
sorry to jump in this thread, however im kinda in the same predicament.. i'll be running a bit launch controll too so need something suitable to hold the power/torque...
Had an exeedy clutch which was holding the power but somethings arsed on it which will be gettin replaced by means of a new clutch.. so im hoping to find a good clutch.. im not arsed about drivability to much if im honest, i want it to handle the torque and the power..
6 puck paddle ACT clutch is what socks runs his 344bhp glanza on, but from race-tech is £345, perhaps one similar to that or just somewhere else cheaper?
CK
  • 4 weeks later...
Someone using Helix organic fast road clutch? I need to buy a new clutch asap, but don't really know what to choose. I would like to buy Blitz, but it's quite expensive and is it aggressive too? I use my car daily, so I don't want any overkill clutch. What you recommend?
Running ct9 1bar with JAM ecu atm.
