Chris23 Posted September 6, 2012 Share Posted September 6, 2012 HOW MANY PEOPLE HERE WENT TDO4 WITH STANDARD INTERNALS? AND WHATS THE RESULT? RELIABILITY?AND WHAT INTERCOOLER PIPING USED?AND SAFE BOOST TO RUN TD04?MANY THNAKS Quote Link to post Share on other sites
Azz Posted September 6, 2012 Share Posted September 6, 2012 (edited) I had standard internals on TD04 at 1.1bar, HDI intercooler, FPR and FCD and a coulple of others bits for around a year.It made 221.4bhp Toyo sports manifold ( EBAY JOB )Standard ecu aswellEngine stayed strong with no problems then i built a forged engine Edited September 6, 2012 by Azz Quote Link to post Share on other sites
akyakapotter Posted September 6, 2012 Share Posted September 6, 2012 I'm rocking stock internals 233.4bhp 210ftlb 1bar of boost mapped my tuning devlopments on emanage blue ewg set up. I use a Toyo sports front mount cut up one of the pipes to suit td04 Quote Link to post Share on other sites
StuDoc 72 Posted September 6, 2012 Share Posted September 6, 2012 The cut off line for safe power on standard internals is classed roughly around the 240bhp mark. Could be more could be less its based on the general health of the engine in question. I believe safe boost is anything upto 1.4 on TD04 depending on what your engine will take. You will need to either buy TD04 piping off someone or have your own made up.The TD04 is the turbo from a subaru so it is an OEM spec turbo therefore is designed for reliability. Quote Link to post Share on other sites
Chris23 Posted September 6, 2012 Author Share Posted September 6, 2012 Thanks all for replying back giving me the confidence to go td04 with standard internals....But the problem is my radiator was leaking last month and i bought from tuning developments jap speed full sized rad....is ok to go td04 with full sized rad? Quote Link to post Share on other sites
akyakapotter Posted September 6, 2012 Share Posted September 6, 2012 I'm use standard rad mate Quote Link to post Share on other sites
fraser280789 Posted September 6, 2012 Share Posted September 6, 2012 im using standard internals,front mount which i believe was meant for an evo,td4 turbo and zisco external wastegate setup,im running 257.1 bhp and im made to believe the highest powered non forged glanza on the tgtt forum which im happy about.soon going td05 1.5 forged. so your now going to need to go td04 because thats when the show begins Quote Link to post Share on other sites
Chris23 Posted September 6, 2012 Author Share Posted September 6, 2012 On 9/6/2012 at 5:01 PM, akyakapotter said: I'm use standard rad mate what is the exhaust manifold you used?thanks again everyone......wow and im suprised all the figuares im seeing. Quote Link to post Share on other sites
har-vey Posted September 6, 2012 Share Posted September 6, 2012 So it's ok to run standard ecu with a td04? Quote Link to post Share on other sites
pick1 Posted September 6, 2012 Share Posted September 6, 2012 U can run standard ecu but I would need rrfpr and an fcd then go get your fueling check on a RR if u have the money buy emanage blue if u have a decent amount of money go for emanage ultimate if u have lots of money go stand alone lol I'm running tdo4 at a bar with stock internals n a cheap td04 kit at 1 bar on emanage blue making 226bhp Quote Link to post Share on other sites
akyakapotter Posted September 6, 2012 Share Posted September 6, 2012 I'm useing zisco external wastegated one take a look at my build thread it's all in there Quote Link to post Share on other sites
Fro Posted September 7, 2012 Share Posted September 7, 2012 I run std internals at a bar on td04 with a power fc making 236bhp. I ran the standard ecu under fuel cut at about .8bar and it was fine but laggy, get a much batter drive with a map. I personally wouldn't push much more than a bar but at the end I the day it's down to how good the map is! 1.4bar has been seen but not for that long! You say you got a rad from tuning developments, is it a full size 40mm alloy rad? I could be wrong but turbo kits that fit a standard rad might not fit with the alloy rad? Quote Link to post Share on other sites
pick1 Posted September 7, 2012 Share Posted September 7, 2012 On 9/7/2012 at 9:12 AM, Fro said: I run std internals at a bar on td04 with a power fc making 236bhp. I ran the standard ecu under fuel cut at about .8bar and it was fine but laggy, get a much batter drive with a map. I personally wouldn't push much more than a bar but at the end I the day it's down to how good the map is! 1.4bar has been seen but not for that long! You say you got a rad from tuning developments, is it a full size 40mm alloy rad? I could be wrong but turbo kits that fit a standard rad might not fit with the alloy rad?Agreed your ally rad will probably be thicker to aid cooling etc so it may be a case of finding a turbo manifold that fits wepr , race tech , u could even give mike a quick bell and ask about there td04 kit as they sold u the rad they may already know if there manifold etc will fit dude Quote Link to post Share on other sites
Broony Posted September 7, 2012 Share Posted September 7, 2012 (edited) Standard internals, 1bar of boost with E-manage Blue, TD04l, wepr manifold and turbo smart ext waste gate, fmic, civic rad, rrfpr.I asked for a safe map too and still got 220hp at the fly. Edited September 7, 2012 by Broony Quote Link to post Share on other sites
Chris23 Posted September 7, 2012 Author Share Posted September 7, 2012 good figures broony with standard internals.how is it coping. thanks for all the feed back Quote Link to post Share on other sites
mark-tozer Posted September 7, 2012 Share Posted September 7, 2012 (edited) im running standard internals td04 1 bar of boost on internal wastgate on a fuel cut defender and a fuel pressure regulator and got 216bhp and running sweets a nut. Edited September 7, 2012 by mark-tozer Quote Link to post Share on other sites
akyakapotter Posted September 7, 2012 Share Posted September 7, 2012 Quote Link to post Share on other sites
Broony Posted September 7, 2012 Share Posted September 7, 2012 On 9/7/2012 at 7:18 PM, Chris23 said: good figures broony with standard internals.how is it coping.thanks for all the feed backReally good mate, boost comes in smooth and hard, just how i like it but yeah td04 kicks you in the nuts, little bit laggy compared to ct9 but worth the extra power Quote Link to post Share on other sites
Sportif 4efte Posted July 30, 2015 Share Posted July 30, 2015 Tdo4 was 1st used in ej20 subaru engines. Quote Link to post Share on other sites
Socks Posted July 30, 2015 Share Posted July 30, 2015 The key is to get a decent map. Fcd and fpr is just pure luck if it lasts. Quote Link to post Share on other sites
Ryan_EP82 GT Posted July 30, 2015 Share Posted July 30, 2015 outta curiosity any of the lads that posted in 2012 still running their td04 setup on stock internals? Quote Link to post Share on other sites
Broony Posted August 6, 2015 Share Posted August 6, 2015 Yep still running mine Running spot on !!!Although not for long as she is getting overhauled this winter ;) Quote Link to post Share on other sites
Matt1878 Posted August 6, 2015 Share Posted August 6, 2015 Mines been TD04 since back then and still running strong... Been at 1 bar Quote Link to post Share on other sites
Luke91 Posted January 20, 2017 Share Posted January 20, 2017 Gota revive the thread some of the cars still going? I'm looking into getting a td and map n sell my plug n play but seems scary with out forged engine. Quote Link to post Share on other sites
akyakapotter Posted January 20, 2017 Share Posted January 20, 2017 On 1/20/2017 at 12:17 AM, Luke91 said: Gota revive the thread some of the cars still going? I'm looking into getting a td and map n sell my plug n play but seems scary with out forged engine.My old engine is still going strong. Quote Link to post Share on other sites
