Right just fitted my emu and updated fuel pump
Turned boost up to .9 bar on td04 took it for a test drive and it sounded wrong
Next minute smoke poring out of bonet
Quickly pulled over and the manifold and exhaust side were glowing bright red
Any ideas???
please as I'm stood at the side of the road
It had a map of 1.2 bar on mate
And don't matter now engine gone pop
Why did you even attempt to turn the boost up? no offence dude but you completely ruined your car in that short space of time! should have gone and got it mapped and no way even messed around with the previous mapping
rings have gone and ino i regret doing it now wasnt too hard a run really but i've got a spare engine sat here so ill have to do a full rebuild and know i have a good engine then
What boost did you run it at phil? If it was mapped to 1.2 bar on a TD04 and you ran say 0.8, Yes its not an ideal setup for your car but it would still run okay if a little on the rich side. Sounds like it has been out on the timing, Or been very lean to cause that much heat.
If it still turns over its hopefully just the rings...
It depends on what size injectors you sould run etc every car is different hence the word getting it mapped! Lesson learnt but it will come out faster stronger better if know you well though Phil :)
Edited by micky boy
nah its my old emu still used stock injectors but it was maped for my car so extremely risky to use on another set up. bad news this mate but forged builds are for winners anyway :p
