dean@mainzcarcare Posted October 19, 2012 Posted October 19, 2012 Purple Rain doing it's thing in the video below http://www.youtube.com/watch?feature=player_embedded&v=M8kE-YdxS4o So this is available on the following group buy terms... So the rules of this group buy are: 1. Add name below 2. Payments are due when we get to 10 interested parties, all payments via PayPal -> paypal@mainzcarcare.co.uk 3. If we don't reach 10 buyers there is no group buy. So normally this product would be £17.23 delivered with UKSO discount, we will do the group buy for £15 delivered, for 1 litre Dean Names ---------- 1. lukEp 2. morgey 3. TrisK 4. RobertR 5. Socks 6. Idrees
dean@mainzcarcare Posted October 20, 2012 Author Posted October 20, 2012 Few more pics of this product in action
StarletMad Posted October 20, 2012 Posted October 20, 2012 I take it the purple shows where the dirt is on the wheel??Cheers
Dan507 Posted October 20, 2012 Posted October 20, 2012 that looks good, is it safe to use with after market painted wheels? at the moment im using autoglym wheel cleaner. it says that your not suppose to use it on certain wheels.
lukEp Posted October 20, 2012 Posted October 20, 2012 (edited) Right few questions start off... How much do you get for the £15 GB or £17.24 NGB. how long does it usually last? considering us starlet people usually have 15"-16" wheels. Why type of surfaces has it been tested on?Thanks Luke Edited October 20, 2012 by lukEp
dean@mainzcarcare Posted October 20, 2012 Author Posted October 20, 2012 I take it the purple shows where the dirt is on the wheel??CheersYeah this basically is an industrial fallout remover and is damn good at removing iron contaimants and brake dust from wheels.It turns purple as it breaks down iron and brake dust yes.
dean@mainzcarcare Posted October 20, 2012 Author Posted October 20, 2012 that looks good, is it safe to use with after market painted wheels? at the moment im using autoglym wheel cleaner. it says that your not suppose to use it on certain wheels.This is safe to use of painted wheels, standard alloys, metal rims, bodywork and has been tested on all of these.Dean
dean@mainzcarcare Posted October 20, 2012 Author Posted October 20, 2012 Right few questions start off... How much do you get for the £15 GB or £17.24 NGB.how long does it usually last? considering us starlet people usually have 15"-16" wheels.Why type of surfaces has it been tested on?ThanksLukeYou get a litre of product from the prices quoted above.1 litre would last you ages tbh, I'd say you would get 10 washes out of a litreSee post above been tested on a wide variety of alloys etc
Bildo Posted October 20, 2012 Posted October 20, 2012 Might be worth mentioning that people won't need to use this with every wash mate, as most people won't understand what an iron fallout remover is etc.For me I probably use Purple Rain (or a similar product) 3-4 times a year or so, this therefore makes it sound more cost effective than it does in the previous post.It can also be used on bodywork to remove contaminants that have built up over time. If I'm doing a full detail I'll often do the lower part of the car with this before I clay (along with a tar remover.) This way you can ensure that most of the contaminants within that area have been removed therefore leaving less for the clay bar to pick up reducing the chance of marring from the clay bar.My personal recommendation is this, (I do it 3-4 times a year to ensure I have good wheel protection all year round:Wash wheel with normal wheel cleaner to remove the loose dirtUse Purple Rain to remove the more stubborn stuff (this also gives Purple Rain a chance to really get on the surface which increases it's performance.)Clay the wheel if necessary.Seal the wheel. (I use Planet Polish Wheel Seal & Shine, absolutely amazing stuff.)Once you've done this then you'll only need to wash the wheel with normal shampoo whilst the protection lasts, it'll be insanely easy to wash and sometimes a hit with a pressure washer alone is enough for a perfectly clean wheel. (Protection using this process normally lasts 3-4 months for me.)Once the protection has gone I'd normally repeat the above process.
dean@mainzcarcare Posted October 20, 2012 Author Posted October 20, 2012 Might be worth mentioning that people won't need to use this with every wash mate, as most people won't understand what an iron fallout remover is etc.For me I probably use Purple Rain (or a similar product) 3-4 times a year or so, this therefore makes it sound more cost effective than it does in the previous post.It can also be used on bodywork to remove contaminants that have built up over time. If I'm doing a full detail I'll often do the lower part of the car with this before I clay (along with a tar remover.) This way you can ensure that most of the contaminants within that area have been removed therefore leaving less for the clay bar to pick up reducing the chance of marring from the clay bar.My personal recommendation is this, (I do it 3-4 times a year to ensure I have good wheel protection all year round:Wash wheel with normal wheel cleaner to remove the loose dirtUse Purple Rain to remove the more stubborn stuff (this also gives Purple Rain a chance to really get on the surface which increases it's performance.)Clay the wheel if necessary.Seal the wheel. (I use Planet Polish Wheel Seal & Shine, absolutely amazing stuff.)Once you've done this then you'll only need to wash the wheel with normal shampoo whilst the protection lasts, it'll be insanely easy to wash and sometimes a hit with a pressure washer alone is enough for a perfectly clean wheel. (Protection using this process normally lasts 3-4 months for me.)Once the protection has gone I'd normally repeat the above process.This is very true this is not something that should be done with every wash, I also do this maybe once a quater Dean
Rob H@RCH Engineering Posted October 20, 2012 Posted October 20, 2012 I mixed mine 50/50 with water and it still works perfect so could go at least 25/75 as a every wash cleaner I am going to try that next but you dont even need to brush the wheel just let the stuff do its job and wash off!!
dean@mainzcarcare Posted October 20, 2012 Author Posted October 20, 2012 Go on then put my name downDone
dean@mainzcarcare Posted October 20, 2012 Author Posted October 20, 2012 Is this the same sort of thing as IronX?Yup same sort of product and smeels just as good ;)
morgey Posted October 20, 2012 Posted October 20, 2012 does this remove ground in brake dust, my wheels have got some really stubborn dirt that nothing seems to shift. the best stuff I've had on it so far was electrical circuit board cleaner (dont ask!) but some of its so old it wont lift! getting to the point of having the wheels resprayed lol
dean@mainzcarcare Posted October 20, 2012 Author Posted October 20, 2012 does this remove ground in brake dust, my wheels have got some really stubborn dirt that nothing seems to shift. the best stuff I've had on it so far was electrical circuit board cleaner (dont ask!) but some of its so old it wont lift!getting to the point of having the wheels resprayed lolI've had great success getting fairly well caked on brake dust off with this product yes
morgey Posted October 20, 2012 Posted October 20, 2012 stick me down for it then. worth a shot i supose
dean@mainzcarcare Posted October 20, 2012 Author Posted October 20, 2012 stick me down for it then. worth a shot i supose Added
TrisK Posted October 20, 2012 Posted October 20, 2012 If it's safe for lacquered polish then put me down
dean@mainzcarcare Posted October 20, 2012 Author Posted October 20, 2012 If it's safe for lacquered polish then put me downCertainly is, added to list
raffa_mk Posted October 22, 2012 Posted October 22, 2012 Where abouts are you based in Sheffield as its local to me, may pop down n pick a bottle up, send me a pm
dean@mainzcarcare Posted October 22, 2012 Author Posted October 22, 2012 Where abouts are you based in Sheffield as its local to me, may pop down n pick a bottle up, send me a pm PM sent
RobertR Posted October 23, 2012 Posted October 23, 2012 Add me too (also need postage to the Netherlands)
dean@mainzcarcare Posted October 23, 2012 Author Posted October 23, 2012 Add me too (also need postage to the Netherlands)Added, would you be wanting the lance as well (as per the PM) if so then it won't be so much extra for the postage.
