morgey Posted December 20, 2012 Posted December 20, 2012 But for £150 if they last even 12months thats 4 years worth of driving about on for the same price as bc's, meisters d2's etc most people wont even own there car that long!And vw coilovers are very good at one thing in particular.... Going fudging looooowwwwww!!! Quote
TrisK Posted December 20, 2012 Posted December 20, 2012 Exactly. I'm not recommending these for v's, or track use or anything But if somebody has an n/a that they just want to put on its arse (Dan I'm looking at you)This could help outBut we need that measurement for the diameter of the spring Quote
morgey Posted December 20, 2012 Posted December 20, 2012 If this measurement isnt correct im sure something could be machined up to fit surely? Quote
TrisK Posted December 20, 2012 Posted December 20, 2012 Yeah. Then we ask Dean or somebody to make us a plateThe standard spring has a plate hereWhich goes under the top mount like so:So we could easily get something like that made to suit Quote
Weyro Posted December 20, 2012 Posted December 20, 2012 (edited) I had similar stuff on my old focus, Jamex coilovers for 180 and they were pretty decentEDIT: Just discovered that the Pro Sport brand coilys are the new name of Jamex. Edited December 20, 2012 by Weyro Quote
morgey Posted December 20, 2012 Posted December 20, 2012 On them vw coilys where does the spring seat? On that silver plate or on the bottom of the top mount?All you are really looking for is the starlet top mount to fit the vw spring cap and them make sure the bearings align or mate properly to allow for the steering to work. And has anyone looked at the rears yet? Quote
TrisK Posted December 20, 2012 Posted December 20, 2012 You don't use that silver plate at all on the vw coils. Top mount seats straight on the spring(The polo coils are for 6n2 and 6n, they come with two front springs (straight spring + silver plate -6n) or (tapered spring and no plate-6n2)Rears as long as the top of the strut is long enough and not too long too tighten down they are both eye mount so should bolt in and be fine as there is mess going on at the rear Quote
dan106 Posted December 21, 2012 Author Posted December 21, 2012 (edited) Haha, lemme show you what ride comfort my previous car hadSo, any 150 quid coilover will be like driving on a frikin cloud!But on a serious note, i do want the sportif properly on the floor as i miss being low and i havent seen a properly slammed (not just a splitter hitting a speedbump, ahem) starlet before!Either way, even if the damper is too wide or too short or whatever, it can always be turnt down and re-tapped!And without out sounding too mickey mouse, itd be easy to get that top spring pan on a polo spring, all you'd need is, an angle grinder some snips and a hammer and maybe cable ties for good measure! Edited December 21, 2012 by dan106 Quote
morgey Posted December 21, 2012 Posted December 21, 2012 Well id say you would stand a good chance of getting them to fit with the 6n straight spring with the plate then the ep top mount. the tapered spring will sit all over the shop against the ep's spring seat plate Quote
StuDoc 72 Posted January 15, 2013 Posted January 15, 2013 What you need measured? Is it really worth while doing though? Those shocks are cheap for a reason mate they are pants. Surely if Dan wants a cheap set up then you would be better off with a good 2nd hand shock and spring kit tbh. Someone posted a newly found make of coilies for starlets cant remember who from or what brand but they were only £350 or sumthing. Quote
TrisK Posted January 15, 2013 Posted January 15, 2013 Diameter at the top of a starlet spring. They really arent that bad mate. I ran them on the polo for 18 months, and although not great for decking an n/a on the cheap they would do Quote
StuDoc 72 Posted January 15, 2013 Posted January 15, 2013 You could maybe find someone with a busted set of starlet coilies and use the top mount from them and a set of meister springs im sure you can get them new for £30 a spring or there abouts. Maybe starts to cause the cost to mount up a little. If no one has measured the diameter ill do it tonight and let you know ive just taken quite a tasty rare shock spring set up off mine for coilies. Quote
JTStarlet92 Posted January 15, 2013 Posted January 15, 2013 we need to get something worked out, it looks like it would work easy enough with minimal work! Id be up for this as I have 13 inch banded steelies in I the pipeline, all I need are some low coils! Quote
griffo20022 Posted September 22, 2013 Posted September 22, 2013 Did anybody ever try this out at all? Quote
Glanza-Ben Posted September 22, 2013 Posted September 22, 2013 Now I've seen this I'm gonna try it, all my mates have polos so will get a coily off them and source a top mount and give it a go Quote
Vincent-ep91 Posted September 22, 2013 Posted September 22, 2013 (edited) defo! ^^ agree with you Edited September 22, 2013 by Vincent-ep91 Quote
RobSR Posted September 23, 2013 Posted September 23, 2013 Few phrases for you all ....- Buy cheap, buy twice.- If a job is worth doing it is worth doing right.- Cheap coilovers are wank. Quote
dan106 Posted October 13, 2013 Author Posted October 13, 2013 (edited) Tried a 6n polo coilover on the back of mine today, bottom bush is 20mm too wide, and the shocks were bottomed out way before it was anywhere near low enough, but the top mounts went straight onPs: I'm on the lookout for some starlet rear coilys haha... Edited October 13, 2013 by dan106 Quote
Glanza-Ben Posted October 13, 2013 Posted October 13, 2013 (edited) Try a mk2 golf rear coil over then as there Longer then polo ones Edited October 13, 2013 by Glanza-Ben Quote
5e colin Posted March 15, 2014 Posted March 15, 2014 Try a mk2 golf rear coil over then as there Longer then polo ones mk2 golf ( rears ) are way to long lads by 4" we need mk1 golf rears and mk2 golf fronts check out my thread on tgtt al is explained http://www.toyotagtturbo.com/forums/showthread.php?107505-the-budget-coilover-setup-for-starlet-(-185%A3-)-under-construction Quote
