Weyro Posted November 26, 2012 Posted November 26, 2012 Just wondering if you need to use any silicone sealant when replacing the rocker gasket?Cheers Quote
Idrees Posted November 26, 2012 Posted November 26, 2012 No, make sure both surfaces are very clean and just use a bit of multi purpose grease on the seal so it's air tight. IdreesID-Workz Quote
Rob H@RCH Engineering Posted November 26, 2012 Posted November 26, 2012 Just in the corners where the cam caps meet the head just put a small line across the seam and the same for the one for the distributor clamp. Quote
Rob H@RCH Engineering Posted November 26, 2012 Posted November 26, 2012 No, make sure both surfaces are very clean and just use a bit of multi purpose grease on the seal so it's air tight. IdreesID-WorkzThis is wrong the Toyota manual states to do the above. because the seal does not squash into the tight corners good enough to make a good seal. Quote
Weyro Posted November 26, 2012 Author Posted November 26, 2012 Cool, thats what i was thinkingcheers Quote
Idrees Posted November 26, 2012 Posted November 26, 2012 In my many years of working on these cars I have never ever used gasket sealer on the cam cover gasket. Just a touch of grease has always done the job perfectly for me. Quote
Rob H@RCH Engineering Posted November 26, 2012 Posted November 26, 2012 They use a grey silicone from the factory, I have the part number for it at home it's in the manual I got from Toyota 15 years ago ya could say I have been building these engines some time too. Quote
ryan lang Posted November 26, 2012 Posted November 26, 2012 ive never used sealant or grease :/ Quote
Asad Posted November 26, 2012 Posted November 26, 2012 when you remove it (if it hasnt been removed before that is) you`ll see the grey sealant...round the timing belt area especially just reapply it after and your good to gois it leaking? if its still soft you dont have to replace it Quote
TrisK Posted November 26, 2012 Posted November 26, 2012 Moral of the story is you have to use sealantbut the offical line, from Toyota, is you should.So if your doing it and dont have any, dont worryif you have some, its not going to hurt Quote
corofin12345 Posted November 26, 2012 Posted November 26, 2012 as rob said... a new gasket wont leak straight away but after a few runs it "will" from those areas he mentioned.. better of doing it right the first time Quote
Weyro Posted November 26, 2012 Author Posted November 26, 2012 Mine was leaking quite alot a while ago, so i took it off cleaned the gasket and the joining surfaces, then put a shit load of sealant on the cap cover things. It was fine for a few months but now its leaking again, think i might have used too much sealant. Quote
starletburkie Posted November 27, 2012 Posted November 27, 2012 i use a small bit of silicone sealant aswell Quote
micky boy Posted November 27, 2012 Posted November 27, 2012 I always wonderd why i had gray silicon sealer near my cam ect when i've took the old rocker cover gasket off!Thanks for that Rob i've never used sealer my self and never had a problem but i might start useing it lol Quote
Got.boost Posted November 27, 2012 Posted November 27, 2012 I all ways use a little bit of loctite premium silicon just on the corners of the camshaft caps and a bit around the distributor and its allways been fine Quote
