Dan B Posted December 2, 2012 Posted December 2, 2012 I have a 99 v which was standard when i got it, the current spec is:Air filterDe cat2.5" system with no boxes and blitz nurspec backboxHks actuatorHks ssqvThe car is quicker now but does fuel cut at high rpm with full acceleration, my question is what's the next mod you would make to this car? Money is unfortunately an issue atm so ecu's etc are out of the question, obviously I'd like to stop it fuel cutting but if I can't do that safely without some sort of management then I'd rather turn the actuator down and run it like that until I can afford it! thanks Quote
ro55ifumi Posted December 2, 2012 Posted December 2, 2012 Unfortunately i would say turn it down if you can't afford management John Quote
Broony Posted December 2, 2012 Posted December 2, 2012 if money is tight, fuel pressure regulator and FCD and get it setup on a RR,But the berst advice is what John has suggested^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Quote
_shaun_ Posted December 2, 2012 Posted December 2, 2012 much the same as above i wouldnt look to any other mod till management was sorted Quote
Dan B Posted December 2, 2012 Author Posted December 2, 2012 Thanks guys I'm gonna do that I want to do it properly especially as it's my daily driver, I've been looking at the emanage blue as they're a good price is this the sort of thing I need? I'm td04ing it at the start of the summer though so I'm wondering if that particular one could be set up for that later on aswel so I don't have to buy different managment again? Cheers lads Quote
Azz Posted December 2, 2012 Posted December 2, 2012 EMB would be just right for you if your on a but of a budget pall, just remember to put rolling road costs onto your budget.TD and Racetech have an offer on iirc for around £500-£600Great for td04 aswell Quote
Dan B Posted December 2, 2012 Author Posted December 2, 2012 Thanks mate I'm thinking maybe save for managment + td04 kit together then get it all set up rather than getting it mapped twice... looks like I've reached my limits for now then! Spose I can uprate some other bits ready for the td04 in the meantime what do I need to uprate I've been told fuel pump, leads, plugs, fmic Quote
Liam_D Posted December 2, 2012 Posted December 2, 2012 As said mate until you can afford management or to go externally gated best bet is to turn the boost down until it dosent hit fuel cut anymore! Quote
Azz Posted December 2, 2012 Posted December 2, 2012 Thanks mate I'm thinking maybe save for managment + td04 kit together then get it all set up rather than getting it mapped twice... looks like I've reached my limits for now then! Spose I can uprate some other bits ready for the td04 in the meantime what do I need to uprate I've been told fuel pump, leads, plugs, fmicdependant on what td04 kit you go for you might aswell need Civic rad, Slimline fan, Fuel pressure regulator, and a clutch that can hold the power. Quote
Simon Posted December 2, 2012 Posted December 2, 2012 Clutch will be the next thing really they often tend to struggle holding an engine running 1 bar through a CT9 let alone a TD04 Quote
Dan B Posted December 2, 2012 Author Posted December 2, 2012 As said mate until you can afford management or to go externally gated best bet is to turn the boost down until it dosent hit fuel cut anymore!Will do I'm running a blitz sus style filter I might try blocking part of that off because it sucks in a lot of air with the meshed topdependant on what td04 kit you go for you might aswell need Civic rad, Slimline fan, Fuel pressure regulator, and a clutch that can hold the power.Cheers dudeClutch will be the next thing really they often tend to struggle holding an engine running 1 bar through a CT9 let alone a TD04Am I looking big money for a clutch? Quote
mark-tozer Posted December 2, 2012 Posted December 2, 2012 Will do I'm running a blitz sus style filter I might try blocking part of that off because it sucks in a lot of air with the meshed topCheers dudeAm I looking big money for a clutch? ive ran a standard blue print clutch on a td04 turbo running fine and that was 215bhp. Quote
pick1 Posted December 2, 2012 Posted December 2, 2012 If u want to uprate your clutch mate as obviously it will last longer when u go td04 I'd go with the TD 6puk clutch there fantastic and real easy to drive with and as above depending what td04 kit u go for u will need to change your rad and fan etc so bare that in mind mate I had all those bits ready for when my td04 kit went on n it makes life loads easier mate if u can cross all the little things off the list Quote
A L 3 X Posted December 2, 2012 Posted December 2, 2012 I turned my boost down mate, month by month bought all the supporting mods, then along the way an external wastegate to stop it creeping, before buying a JAM ecu as one of the last things, hard to resist the urge to turn the boost up but was worth it.By the way, your exhaust, how does it sound with the no mid boxes? Quote
Starbo Moorley Posted December 2, 2012 Posted December 2, 2012 I have a 99 v which was standard when i got it, the current spec is:Air filterDe cat2.5" system with no boxes and blitz nurspec backboxHks actuatorHks ssqvThe car is quicker now but does fuel cut at high rpm with full acceleration, my question is what's the next mod you would make to this car? Money is unfortunately an issue atm so ecu's etc are out of the question, obviously I'd like to stop it fuel cutting but if I can't do that safely without some sort of management then I'd rather turn the actuator down and run it like that until I can afford it! thanks You coming jdmc meet tomorrow night ? Been with Dean today and he was telling me and Jack about your exhaust. Quote
Dan B Posted December 2, 2012 Author Posted December 2, 2012 I turned my boost down mate, month by month bought all the supporting mods, then along the way an external wastegate to stop it creeping, before buying a JAM ecu as one of the last things, hard to resist the urge to turn the boost up but was worth it.By the way, your exhaust, how does it sound with the no mid boxes?Cheers for that mate, it sounds really deep and growly on tickover it's quite quiet if you keep the revs relatively low but when you accelerate harder it gets quite loud but very deep it's a nice sound and when you lift off and accelerate again it pops etc I'm pleased because I was worried it was gonna sound like a Saxo with a 4" backbox on it lolYou coming jdmc meet tomorrow night ? Been with Dean today and he was telling me and Jack about your exhaust.Alright mate yeah I'll be there are you goin down with dean? Quote
Starbo Moorley Posted December 2, 2012 Posted December 2, 2012 Ill be there in Jack ctr's glanza and will hook up with Dean when were there, im sure hell introduce us mate so ill probably see you tomorrow. Quote
A L 3 X Posted December 3, 2012 Posted December 3, 2012 Cheers for that mate, it sounds really deep and growly on tickover it's quite quiet if you keep the revs relatively low but when you accelerate harder it gets quite loud but very deep it's a nice sound and when you lift off and accelerate again it pops etc I'm pleased because I was worried it was gonna sound like a Saxo with a 4" backbox on it lolNo worries mate, and ah so would you recommend it then? Been looking at getting Dean to remove the silencers from my Fujitsubo system thats all? Quote
Dan B Posted December 3, 2012 Author Posted December 3, 2012 No worries mate, and ah so would you recommend it then? Been looking at getting Dean to remove the silencers from my Fujitsubo system thats all?Yeah I'd recommend it mate Quote
Starbo Moorley Posted December 3, 2012 Posted December 3, 2012 I took midbox of my japspeed and that was fine, i now run a straight front exit and thats not as loud as you think itd be. Quote
ro55ifumi Posted December 3, 2012 Posted December 3, 2012 (edited) If you are staying on a standard motor, you don't need a fuel pump, you will need an FPR, i switched to TD04 on standard internals, standard fuel pump standard injectors, FMIC,Magnecore leads, Race Tech Externally Gated TD04 set up, EBC will be needed, E-mange Blue(which now runs my forged set up) and made 237bhp @ Tuning Developments.TD offer is £550 for emange + fitting + set up on RR, Rickys is similar but you have to have one of his kits for the deal.A TD04 kit from either is around £1300-£1400 for an external gated mani,down pipe,td04 + external gate.Probs looking at just short of £2000 if you were to buy new.John Edited December 3, 2012 by ro55ifumi Quote
Amjad Posted December 3, 2012 Posted December 3, 2012 You don't need £1000+ to buy a TD04 setup by the way, WEPR have a December sale on and you'll pay about half that Quote
Dan B Posted December 3, 2012 Author Posted December 3, 2012 Cheers lads RW developments is doing mine, to be honest I'd be happy with 200bhp like Quote
