as far as i know its oem rad friendly dude but its very tight, there was a few cases that it was that tight the movement of the engine punched a hole in the rad from the actuator
prob best going with the civic rad just to be on the safe side
Thinks for that idrees :)
Im not a fan of the civic rads i know alot of people have ran them without any problems! But think the fins on them are made out of tinfoil and bed very easly!..So would like to keep the standard Rad!
Cheers mate!
Yeah i did think of that and was abit worried about the movement of the engine! Im buying the bits over time so think ill give it a test fit to see how much room there is and if theres not much ill have to go for the civic Rad!
Edited by micky boy
Bit of a heads up dude, I used toyo sports as it was easy and cheap but it lasted about 1000 miles them the mani blew into 3 pieces.
Many people have had issues with them cracking ect......
Save up and get a better one which is what I wish I did to start with
Cheers for that Azz!
Yeah i also know a few people that have had nothing but trubble with them cracking etc but they have all been stainless steel! Im planning on going mild steel! Not to sure if they are any better though? lol
Agreed, the Civic rads are good and a worthy investment. It makes life so much easier when working in the engine bay. We have them available brand new. :D
Yeah i know im just a fussy bugger lol i had a civic Rad on my old V and the fins bent just off flys hitting them lol they are soft as shit!
Haha id be buying a civic rad from you any idrees as your service is second to non :)
Edited by micky boy
Mine was a mild steel pall, and 3 pieces later I went to iddy and got a wepr kit !!
Just the shear weight difference you can tell the quality
I have had a Toyosports TD04 mild steel on my car +2 years now with no issues at all. It has been braced and extra welds added so that could be the reason it's lasted.
In regards to the topic my car uses a n/a rad so the TD04 actuator has enough clearance, no issues with temps etc and looks OEM, I tried a civic rad and it just looked bodged.
Did you do it with a proper mounting kit? or a fabbed one?
With tie wraps, thats probably why it looked super bodged but I also didnt like the way it stretched and moved the rad hoses and it didnt cool as well as the standard n/a rad.
With the mounting kits they sit right.
I found mine cooled better than the standard glanza rad, so i find that suprising.
Although i was only looking at a temp gugage rather than working with numbers, so it wasnt an exact science
