iamlegend Posted December 20, 2012 Posted December 20, 2012 (edited) well the bottom bolt shredded to bits stopped me removing it so the only way was to angle grind it out! so we go away and do it and this happend ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh (cheers DAD )so.. what do you thnik i should do?? will say its not actually deep but dunno looks bad??so if needing to replace.. is it the whole unit.. like brake disc etc or what?id say you could put 5p coin half way in Edited December 31, 2012 by iamlegend Quote
daniel_g Posted December 20, 2012 Posted December 20, 2012 Get the welder out haha Or buy a hub off a breaker Quote
iamlegend Posted December 20, 2012 Author Posted December 20, 2012 Get the welder out hahaOr buy a hub off a breakercast iron thow.. would make it worse me thinks Quote
drongo boi Posted December 20, 2012 Posted December 20, 2012 I'd say buy another hub to be safe lol Quote
starletburkie Posted December 20, 2012 Posted December 20, 2012 low hydrogen rod will weld cast but i think it will be ok the way it is! just get a better man on that grinder lol Quote
jezza Posted December 20, 2012 Posted December 20, 2012 I doubt it would fail but would change it for peace of mind. Shouldn't be too costly for a used hub. I'm puzzled how he cut it at that angle, nowhere near the bolt. Quote
morgey Posted December 20, 2012 Posted December 20, 2012 (edited) Just get a new hub and bearing, hub shouldnt be too much off of here and a bearings what £25-30 if the new hub even needs a new one!brakes, ball joint etc are all removable and reusable on the new hub, better be safe than sorry IMOI say new hub i mean 2nd hand off a breaker ;) Edited December 20, 2012 by morgey Quote
iamlegend Posted December 20, 2012 Author Posted December 20, 2012 that bolt is turned around and was the other way jezza.. so i only need hub.. seems the front brake is all attached thow in 1 Quote
morgey Posted December 20, 2012 Posted December 20, 2012 The brake bolts on infont of and next to the shock and one lower down, 2 either 14mm or 17mm headed bolts Quote
starletburkie Posted December 20, 2012 Posted December 20, 2012 all you need is a hub the rest comes off via bolts Quote
morgey Posted December 20, 2012 Posted December 20, 2012 (edited) Yea if you look at this pic />http://i892.photobucket.com/albums/ac122/stuartmurphy/Project%20V/HPIM2895.jpgYou can see the two holes where the brake carrier would bolt onto it. The arm to the bottom right is the one you cut through and the one at the top right is the steering arm Edited December 20, 2012 by morgey Quote
mech5107 Posted December 20, 2012 Posted December 20, 2012 I wouldn't care...it is not that serious...from the pic uploaded... Quote
micky boy Posted December 20, 2012 Posted December 20, 2012 (edited) If i know you mate you'll change it anyway! And i would for pice of mindNext time you come across a problem like that buy one of these!http://www.ebay.co.u...cat=0&_from=R40And yeah its just the hub you need to change Edited December 20, 2012 by micky boy Quote
iamlegend Posted December 20, 2012 Author Posted December 20, 2012 cheers lads for the input!! idrees is getting me sorted legend! Quote
MARK@CMBAUTOS Posted December 20, 2012 Posted December 20, 2012 (edited) If u ever have a rounded nut in the future buy these u won't regret it ! I use then near every day we call them the life savers />http://item.mobileweb.ebay.co.uk/viewitem?itemId=140897818242&index=5&nav=SEARCH&nid=67599409128There a lot better that a nut splitter there cunts of things and hardly every work or u never have room to use it Edited December 20, 2012 by MARK@CMBAUTOS Quote
starletburkie Posted December 20, 2012 Posted December 20, 2012 id have left it like it was x2 it would be ok Quote
Sparky Posted December 20, 2012 Posted December 20, 2012 yep thats just a graze, pretty tough old cast iron lol Quote
lew777 Posted December 20, 2012 Posted December 20, 2012 low hydrogen rod will weld cast but i think it will be ok the way it is! just get a better man on that grinder lollow hy rod would not weld to cast more than likey just crack.they did make cast rods but unsure if you can still get hold of them Quote
iamlegend Posted December 31, 2012 Author Posted December 31, 2012 all sorted and replaced with another yeySORTED!! Quote
