Matt1878 Posted January 6, 2013 Posted January 6, 2013 (edited) Well, I decided to do a 4th gear pull today to see what my boost gauge was reading after I've fitted the JPerformance Manifold and the Blitz Decat..Acording to my gauge (which isn't the best) showed that I peaked at exactly .7 bar but then dropped of to .6 further up the rev range..Is this normal? What could cause this?My setup is:Standard CT9 Turbo JPerformance ManifoldBlitz Decat Blitz Nur Spec ExhaustRW Developments Relocated FilterStandard Actuator Autogauge Boost Gauge Greddy Type S BOVAny help is appreciated ..Matt. Edited January 7, 2013 by Matt1878 Quote
starletburkie Posted January 6, 2013 Posted January 6, 2013 thats ok make for stock actuator and turbo Quote
daniel_g Posted January 6, 2013 Posted January 6, 2013 My setup will be similar to yours when i'm up and running, you hitting fuel cut ? Quote
Matt1878 Posted January 6, 2013 Author Posted January 6, 2013 Not at all dude... Holds well at bang on .7 bar and then drops off slowly towards the top of the rev range... Fuel cut kicks in at .85bar Quote
daniel_g Posted January 7, 2013 Posted January 7, 2013 Thats properly surprising for standard ct9 and actuator, mustn't have any cracks in your wastegate then. Quote
Matt1878 Posted January 7, 2013 Author Posted January 7, 2013 If not then that would be a rare sight on a CT9 wastegate lol Quote
daniel_g Posted January 7, 2013 Posted January 7, 2013 Mine has no cracks at all, yet to run it though so the seals are probably well fucked haha. Think its a ct9b though, gonna check tomorrow. Quote
A L 3 X Posted January 7, 2013 Posted January 7, 2013 Try a HKS actuator, my boost dropped off when the car was standard, fitted a HKS actuator, the boost came in much quicker and harder, and didn't drop off .Mines for sale if you need one, been lying around since I went external wastegate. Quote
turbo Grant Posted January 7, 2013 Posted January 7, 2013 I found filter relocator made it pull hard all the way to redline. Quote
Sefton-EP91 Posted January 7, 2013 Posted January 7, 2013 Mine holds at .7 bar and sometimes creeps to .8 then slowly drops back to .7 again. Sounds normal so I wouldn't worry about it Quote
DavidAshton Posted January 7, 2013 Posted January 7, 2013 It will be your stock actuator that is causing you to loose boost higher up the rev range. The spring inside will be weak and letting the wastegate fully open so you arn't maintaining a steady boost level.An aftermarket actuator will allow much more stable boost control, then you may want to add an electronic boost controller to get things spot on. Quote
StuDoc 72 Posted January 7, 2013 Posted January 7, 2013 Its your actuator like said above? Since you have no management I'd leave it exactly as is. You want to stay away from fuel cut as much as possible as constantly rattling off it isnt good for the car.I'd fit an HKS actuator and set it to about .5 or .6 even tho u wont reach .7 like you do now I n garuntee the better holding of boost makes it feel more powerful.I have a tongs ct9 just now with an HKS actuator as im waiting to get more stuff before mapping my emu and even as it is the .5 pisses all over standard ct9 at .9 just a smoother and bigger delivery. Quote
Matt1878 Posted January 7, 2013 Author Posted January 7, 2013 I will be getting a hks adjustable actuator very soon and I have placed an order with james@cjperformance for a depo EBC.These combined and I should be able to keep a steady boost level.. Matt Quote
Socks Posted January 7, 2013 Posted January 7, 2013 CT9's run out of puff at the top anyways...But all the above will help Quote
Collins611 Posted February 11, 2013 Posted February 11, 2013 just seen this post mine is very similer I have Massive costem intercooler 3inch custom exhaust Ct9 2nd generation hybrid turbo Decat Upgraded fuel pump And recently fitted hi flow mani (hoops verion) Standard ecu butsoon to be jam ecu Currently set up 0.9 but loooses boost goiin up rev range to 0.6 I also have ordered a hks actuator to see if it holds boost. If it dose gonna set it to 0.7 happy days Quote
Amjad Posted February 11, 2013 Posted February 11, 2013 Surprised you didn't do the actuator earlier! On HKS actuator ported CT9 mine holds 1.0-1.1 perfectly Quote
Matt1878 Posted February 11, 2013 Author Posted February 11, 2013 I now have a HKS actuator and a depo EBC... Yet to be fitted but should make a good difference Quote
