There's no point upgrading the turbo without fitting bigger stoppers
Picked up rebuilt Celica ST162 calipers from Russ (legend) which have a larger piston and pad diameter not to mention alot thicker disc for better heat dissipation
New drilled and grooved discs on the way at the minute to finish off the new conversion..and a comparison against the stock brakes (pictures dont do it justice theyre a brave bit bigger!)
Edited by Ryan_EP82 GT
  • Replies 193
  • Created
  • Last Reply
Top Posters In This Topic
Also needed to get something new to handle the torque of the TD04..Nice new genuine Exedy clutch.
And then i got an offer i cant refuse to pick up a Mocal oil cooler, 9 row so perfect for the 1300s.
How much power you planning on running mate? That clutch gonna stand up? Im in the same position looking for a suitable clutch for a td04 at 1bar
Ollie im gonna go for 1 bar myself mate i expect it to hold its own for a good while yet if i get a year out of it ill be happy enough! Lol
Was thinking of a paddle clutch mate but i wanna keep the smoothness they can be a bit juddery on take off!
Any ideas yourself what your gonna run lad?
  • 1 month later...
No progress the last while but I did get the Starlet along to its first rolling road session a few weeks back at Autotune N.I.
Made 176.6 bhp @ 6403 rpm, 155 hp at the wheels
And the torque measured 153.4 lb-ft / 208 Nm
I predicted 165 bhp so safe to say im a happy man for the time being :thumbsup:
Tbh id be pretty happy. 155hp atw, would probably be more like 185hp fly. 20hp transmission loss is probably a bit to little. And since they measure from the wheel then convert to fly, the wheel figure is the genuine reading.
So good work dude
Tbh id be pretty happy. 155hp atw, would probably be more like 185hp fly. 20hp transmission loss is probably a bit to little. And since they measure from the wheel then convert to fly, the wheel figure is the genuine reading.So good work dude
Thanks man it exceeded my expectations makig that power so any more would be a bonus I suppose.
ts running 12psi daily and at the dyno Mike. I dont wanna push the turbo too hard as I've a td04 set up to go on shortly but I wanted a figure for the current setup.
There's no chance a ct9b would make that much power at a bar man this isnt a hybrid one unfortunately.
  • 4 weeks later...
  • 1 month later...
I rebuilt my engine last year and cost me 304 quid. I rehoned it myself got some second hand pistons. Brand new rings and bearings from Toyota. And a head set from euro car parts for 85 quid. Don't take that long either bud
LOL THIS Whey to go :D
Newly rebuilt Mikey. Head and block both fully cleaned and rebuilt with genuine toyota gasket set, valve stem seals, toyota rings but I cchoose acl main and big end bearings. An acl thrust washers.
  • 1 month later...
Unfortunately no progress at the minute as ive decided to fabricate my own ext.wastegate manifold and screamer using the toyoshite as a mock.
In the meantime this arrived from Whitenoize :) gentleman to deal with even threw in free fan mounting brackets thanks bud!
Triple core half rad for the td04 kit :)
  • 3 months later...
Finally getting back to making some progress :thumbsup:
Short shifter arrived yesterday so lashed it in last night
Now i can finally get around to fitting this 8)
My 6 speed box...
Fitted these solid shifter bearings today, total cost £3. Nice upgrade too they make the gear selection really tight and accurate now with the short shifter..
  • 3 months later...
So ive finally got the g6r six speed conversion done and waited off on this little piece of jdm porn to be fitted before i could swap the box..
The car feels completely different with the new ratios in it and it pulls like a train now I was well impressed with the liveliness of it in every gear. The addition of the Toda flywheel to help it rev easier only helps with the acceleration when combined with these close ratios.
I said I was finshed for a while but as you know things pop up now and again and you cant help yourself :D
This is the definitely the last thing im buying for a while. .again lol
