12 hours ago, Mostyn said:
@Jay85 it's spluttering like hell only in boost runs perfect out of boost, running a td04 external gate changed dizzy cap and rotor arm,plugs,turbo,king lead,ignitor
really doing my head it
I've already said mate ? Look^
Did you check the plug gaps before fitting? Incorrect gaps canrun fine on normal driving but will fail under load.
Yeah they're spot on.... and done a diagnostic code earlier and no codes came back
@T-dogChecked timing yestarday and that's spot on, @gorganl2000 Plugged in the carmanscan diagnostics yesterday also and it said the map sensor was reading 8psi constant even withought it running so not sure if that's right, @gibby1980 running dastek
Try changing that map sensor and do a diagnostics test again. See if it's the same. Does the software for the dastek show the same 8psi? I would see that in tunerstudio for the Megasquirt. Confirm if the dastek is tuned for the higher rpms/boost?
Ok I shall do that whenever I can get my hands on one, How would I test that? It was running fine untill I was going up the dual and suddenly lost power and then started spluttering when in boost
