gaz Posted September 12, 2007 Posted September 12, 2007 lol rsm. Yeah i hate putting things back together. Quote
Toby@ToyTuning.com Posted September 12, 2007 Posted September 12, 2007 Looking good Mark, nice to see it all documented. Your on the right lines, the loom can be a real pain when you come to start the car. I went a little overboard on a loom last year and couldn't get the car to start. As long as your careful then you should be okay. Personally we couldn't loose the heaters, we've run without a dash before and it causes big misting problems with our sparadic weather, not ideal when your on the track. We used a portable heater in the car but even that wasn't enough, not to mention how cold it can get in those early/late summer months.Were now using the dash and heater matrix again, most of the crap within the dash has been removed leaving the bare minimum. We were also struggling to mount the gauges/electronics. There are 7 Greddy gauges, a 120mm apexi tacho with shift light, 2 Sard gauges. Sard Fan Controller, Sard I/C Controller, Link Boost Control Unit, Tein EDFC controller, not to mention the sat nav and radar dectector. Without the dash it would be hard to install everything whilst keeping it accessible unless I had made a custom dash which I don't have time to do, yet.You've removed most of the essential items, sound deadening is a painful task but worth it none the less, as you say it all counts. Not sure on what you have but you can consider the following as well:Carbon BonnetZep FRP FendersLexan WindowsFront Bumper Side Exit Exhaust (less material)Lightweight Fuel TankFRP Doors (Custom Job)FRP Rear HatchTitanium Washers/Bolts/NutsWe are releasing Lexan lightweight window sets for the EP82 and Ep91 very soon, kits will include front side windows, rear quarters and rear hatch. These will save 60% of the window weight, are scratch/UV resistant and used commonly in Motorsport, one of the best materials. A custom fuel tank isn't too expensive and can save a substantial amount, we tried desinging an alloy tank for the front foot well. 35L meaning the weight was kept nearer the front where it should be on a FWD but space was limited and it meant loosing the passanger seat for good so we mounted it in the rear where the seats used to be. You can then use two fuel pumps and a swirl pot to feed the rail and prevent fuel starvation. After this it will start to get expensive, un-sprung weight is where it's but custom fabrication can be costly as I'm sure your aware.Keep us up to date and we must meet soon as am sure your pretty close.Best Regards,Toby Quote
Nanglebadger Posted September 12, 2007 Posted September 12, 2007 awesome work there Mark once again dude!! keep at it!!! will be awesome to see it all start to go back together too so we can all see the vision u have in your head for the car too!!!is it just me or does everyone here wish Toby would do an indepth thread on his car in the rides section!????!!!??? i for one have never seen his car and it sounds UBER!Phil. Quote
riko666 Posted September 12, 2007 Posted September 12, 2007 i've seen it, but that's cause my car's always being repaired at the shop where his car is ;) Quote
Sparky Posted September 12, 2007 Posted September 12, 2007 is it just me or does everyone here wish Toby would do an indepth thread on his car in the rides section!????!!!??? i for one have never seen his car and it sounds UBER!Phil.I'll second that ;) Quote
Toby@ToyTuning.com Posted September 12, 2007 Posted September 12, 2007 Good things come to those who wait, while off yet.Forget to mention lightweight pulleys Mark, p/steering, alternator, waterpump, crank etc..Thanks,T Quote
riko666 Posted September 12, 2007 Posted September 12, 2007 even lightweight engine internals - pistons, connecting rods, valvetrain, crankshaft (a lot of potential there) etc...Carbon Fibre Driveshafts wouldn't be bad in price considering how small they are Quote
NightSpirit Posted September 13, 2007 Author Posted September 13, 2007 How much are the Zep fenders? could do with a set of them...Lexan in the future.Front exit exhuast you say? what about noise levels on the track...how would you silence it to any degree...when I swap the engine out I may well do this.by the way, on the loom front, I'm almost there. I've traced a number of wires to the front fuse box and am struggling to get to the source of them (fuse box is a ball ache) So far there have only been 2 wires redundant that go to the ECU plugs, both to the small plug. Quote
gaz Posted September 13, 2007 Posted September 13, 2007 If company's like RC developments can get away with noise levels on front exits exhausts then you should easily be able to, i guess if they are too loud they are just baffled, or have some kind of control valve. Quote
riko666 Posted September 13, 2007 Posted September 13, 2007 you have the advantage of the turbo which will silence the car a lot more than you think Quote
NightSpirit Posted September 13, 2007 Author Posted September 13, 2007 I used to run a straight through pipe on my MR2 for a while....that thing was LOUD. It should be piss to get the exhaust coming out the passenger side ;) Quote
NightSpirit Posted September 14, 2007 Author Posted September 14, 2007 Well last night I got a few minutes spare to plug in the speedo, the various connects and earths and attempt to fire the car up....hey presto, she's alive ;) Quote
SiCaln Posted September 14, 2007 Posted September 14, 2007 great news man well done, hope im as lucky Quote
NightSpirit Posted September 14, 2007 Author Posted September 14, 2007 Well if only trace the redundant plugs to their source and remove them there...they shouldn't affect anything else. Also if the plug source connects to something else that then only has 1 wire etc...that's safe to remove aswell, kind of work it that way. I still have about 10 wires going to the front fuse box that need removing from the plug in the box and I also have 2 wires going to the ECU plugs that are redundant too o_0 Quote
jon5698 Posted September 14, 2007 Posted September 14, 2007 Looking good mate, on the front exit exhaust i am sure you have to have it coming out of the drivers side for it to be legal. Incase any pedestrians get caught by it, fuck knows how that would happen like he he. Quote
NightSpirit Posted September 14, 2007 Author Posted September 14, 2007 Looking good mate, on the front exit exhaust i am sure you have to have it coming out of the drivers side for it to be legal. Incase any pedestrians get caught by it, fuck knows how that would happen like he he.We've had this discussion I think...passenger side is legal also, look at the Transit van Hoping to be ready to bind up the loom this weekend!Update time ;)Check out the Dremel action on that binnacle pod.... Quote
Nanglebadger Posted September 15, 2007 Posted September 15, 2007 congrats on gettin her to fire up first time Mark man thats great news!!!!!! well done dude!!lookin good man! keep up the hard work!Phil. Quote
riko666 Posted September 15, 2007 Posted September 15, 2007 well just finished removing all signs of carpetting/plastic trim (bar the sidesills to cover the wiring) in my car - one question, I take it you need to have the dash off to get rid of the sound deadening on the firewall right? Or is there a way of just ripping it out...I was worried about all the wiring about ;) Quote
SiCaln Posted September 15, 2007 Posted September 15, 2007 thats nice work man very impressive gna pass an MOT tho?! Quote
Nick_p Posted September 16, 2007 Posted September 16, 2007 Good work dude and congrats on getting it started up first time, must have been a bit of a relief ;) Quote
NightSpirit Posted September 16, 2007 Author Posted September 16, 2007 Yeah bit of a relief I've finished the fuse box now and rewrapped it all. One more check to see she runs then I can tidy up the interior.Riko, to get to that sound matting easily the dash has to come out yes! If you've ditched the heater system it's possible to get to most of it but still hard work.It should be ok for MOT still aswell Quote
riko666 Posted September 16, 2007 Posted September 16, 2007 meh, I want to keep the heater for the winter months - not for keeping warm, but for the dreaded mist. Also, is the A/C condenser pretty much that huge, errr...for want of a less blonde word....thing on the passenger side of the dash? If so I'll probably take that out tomorrow when I'm bored Quote
NightSpirit Posted September 17, 2007 Author Posted September 17, 2007 meh, I want to keep the heater for the winter months - not for keeping warm, but for the dreaded mist. Also, is the A/C condenser pretty much that huge, errr...for want of a less blonde word....thing on the passenger side of the dash? If so I'll probably take that out tomorrow when I'm boredBasically,Yeah lolBehind the dash from the glovebox is the heater matrix, but behind the center console is the heater control main bit (technical aren't I) you'll need to remove that too to get to the deadening and all that gay carpeting. Quote
NightSpirit Posted September 17, 2007 Author Posted September 17, 2007 Some more updatedness...Finished the fuse box area, the car starts still which is good.Decided to remove the gay alarm (it's not gay, it's just wired in gay) so gotta finish that off....bloody cat 1.But anyway...piccys, flocktastic. Quote
Guest Enzo Posted September 17, 2007 Posted September 17, 2007 haha minted! hats off to you man thats a home made flocking kit yea ? Quote
