snails ep91 Posted April 18, 2013 Posted April 18, 2013 (edited) getting fed up now.. cant see where this plugs too! its the light loom that comes back around and in to the car in the drivers footwell its the white plug thats unconnected anyone help? cheers Edited April 29, 2013 by snails ep91 Quote
StuDoc 72 Posted April 18, 2013 Posted April 18, 2013 (edited) Steering column plug? Looks a bit far away Maybe its just a spare? is it a turbo loom in an N/A? Edited April 18, 2013 by StuDoc 72 Quote
AdamB Posted April 18, 2013 Posted April 18, 2013 How many pins is it dude? Looks like a connector which goes into the fuse box (interior) Quote
StuDoc 72 Posted April 18, 2013 Posted April 18, 2013 How many pins is it dude? Looks like a connector which goes into the fuse box (interior) Very right thats exactly what it looks like and the length looks right for that too! Quote
snails ep91 Posted April 18, 2013 Author Posted April 18, 2013 ill look tonight guys. its theloomthat travelsright around from the lights under the drivers wing and back into the cabin and its a 96 turbo loom in an n/a. and ifit was a flux capacitor i should be able to recycle allmy rubbish,dump it in there and it would fly! unfortunately it runs on petrol,electricity and wires (and just storesallmy rubbish) and thats why its still sitting in my bloody garage! lol Quote
bucketep91 Posted April 18, 2013 Posted April 18, 2013 I think its for electric mirrors. Could be wrong tho i have a few plugs in that area that arent used and everything works. Quote
daniel_g Posted April 18, 2013 Posted April 18, 2013 I think its for the ABS on the Glanza loom, it would plug into the ABS ECU and they sit around that area. Quote
snails ep91 Posted April 18, 2013 Author Posted April 18, 2013 (edited) yeah i think it is. cheers guys. seeing as i dont have abs ill be fine leaving this unconnected right? Edited April 18, 2013 by snails ep91 Quote
daniel_g Posted April 18, 2013 Posted April 18, 2013 Yeah, you wont be able to connect it to anything anyway, unless you have the ABS ECU. But even then it wouldnt do anything lol. Quote
rob_bower Posted April 18, 2013 Posted April 18, 2013 Yes it's for abs there is another large white plug in the centre that doesn't plug in one of the blue plugs is elecric mirrors. Ate you running a glanza rear loom. And roof loom? If not you will have several plugs that don't match. Quote
snails ep91 Posted April 29, 2013 Author Posted April 29, 2013 Ok got another one guys and this is a little more confusing... its the loom that comes along the drivers side floor from the rear lights i think. i cant find the plug that it connects to anywhere! this is the offender im talking about (grey plug) http://s1223.photobucket.com/user/snailsep911/media/7DA3C028-2442-43D5-AD32-89F793E97B88-885-000001149E5A7B86_zps541b0d44.jpg.html'>http://s1223.photobucket.com/user/snailsep911/media/FAFCDA0C-03FB-49E2-A843-7F3A4A74D08D-885-0000011499A12D2B_zps15c7a1da.jpg.html'> im running a 96 engine and interior dash loom. the rear loom is from a turbo converted n/a so it runs the rear light setup etc. but the issue i have is this rear loom fits my fuel pump connection and has a walbro wired in to fit. Its been removed of all the unneccesary wires etc but i just cant find where it connects to.. now i do have the standard 96 rear interior loom i could use, but again i have looked at the loom and the same wires that come through in the same place i cannot see where it connects to under the dash?! it is oddly a different connection to the plug i have in there now aswell. also changing to the rear 96 glanza loom also poses the problem the fuel pump connection will not fit so this will require rewiring in and i wouldnt have clue where to start with that lol anyone help lol if anyone hasnt noticed.. i hate wiring.and this car tbh sam Quote
bucketep91 Posted April 29, 2013 Posted April 29, 2013 I had this problem too mate, i had to swap the rear loom as that has the male plug.Theres an identical plug right in the middle of the dash loom that it should plug into, the turbo rear loom has a male plug instead of another female like the rear loom you have on ther now Quote
snails ep91 Posted April 30, 2013 Author Posted April 30, 2013 i know... its such a pain. the plug that meets in the middle though connects to the wiring from the fuel pump though right? gonna have to swap looms over i can tell... but with the glanza rear loom that has the male connector coming up the drivers side, i still cant see where that connects too either?? :s so close to throwing in the towel with this thing. just did an oil change and the magnetic sump plug just sheared off in the sump. one thing after another Quote
snails ep91 Posted April 30, 2013 Author Posted April 30, 2013 also, bucketep91.. could you get a pic oif how the glanza loom connects to your fuel pump? the rear glanza loom has a white male plug but my fuel pump plug is completely different and i think im gonna need to rewire this plug to fit if possible. Quote
yaristurbo Posted April 30, 2013 Posted April 30, 2013 sorry?? could you explain.. lolJust shout it out and you'll feel loads better Quote
bucketep91 Posted April 30, 2013 Posted April 30, 2013 Yeah so your using the white plug on the rear loom in the grey fenale plug on the dash loom? I had mines like that too but swaping out for the turbo loom solved my issues and everything works. Mine was a 96 rear loom and it wired into my rear lights and fuel pump without modifying it, my cars a 99 so it might be a straight swap. I would get you a pic mate but ive just refitted the interior and i dont think ill get time to pull it apart again. The turbo rear loom will get you running, i guarentee it Quote
snails ep91 Posted April 30, 2013 Author Posted April 30, 2013 well mine isnt easy like that. because its a piece of shit. that hates me. So this is the plug in comparison that comes up the drivers side on the 96 glanza loom. in comparison to the modified loom i have.. http://s1223.photobucket.com/user/snailsep911/media/0B5CE4DA-6FEC-4C13-AE6B-554ADA18284F-1495-000000C0D51EE392_zpsc32467fb.jpg.html'> As you can see the loom i have is a grey female plug,but the glanza loom is a white male plug. The problem is i still cant find a female plug on the dash loom to connect the 96 rear glanza loom :s couldsomeone with a stripped glanzashowmehow theresconnects up?? wouldbe really helpful. and then one other thing,ifichange to the 96rearloom, ill need to change the fittingtofitthefuelpump. so this is the fitting on my fuel pump and the modified loom i have http://s1223.photobucket.com/user/snailsep911/media/70F9ADDC-826C-438C-931D-96F9E5D60B1B-1495-000000C0E53A3CE7_zps9b8dee80.jpg.html'> http://s1223.photobucket.com/user/snailsep911/media/8EF2A02D-004E-41AD-9474-3B2BE773F5BF-1495-000000C0E102333A_zpsad45966b.jpg.html'> This is the fuel pump connection on the 96 standard glanza loom i have. http://s1223.photobucket.com/user/snailsep911/media/B1273D12-8DCA-4850-9765-9197303C7709-1495-000000C0DB3960DC_zpse7a66b72.jpg.html'> The wires are the same colour, can i just solder on the right connection to the 96 loom? Quote
rob_bower Posted May 1, 2013 Posted May 1, 2013 Yes you can just join the wires which are the same together. As for the plug in the foot well I couldn't find the relevant plug either so socks came over to give me a hand and wired wired it. You will have some spare plugs under the dash some of the wires will match the wires in the loose plug. FromMemory it's just a case of joining them together. If in doubt we tested tll the wires in the plug with a multimeter if it was earthed we left it if there was no circuit we fed 12v to it to see what it did. It was mainly rear lights, no plate lights etc.What have you don't about the roof loom? Quote
