Browner Posted April 30, 2013 Posted April 30, 2013 ITEM: JAM Racing Plug & Play ECU (EP91)CONDITION: Excellent. Working perfectly.EXTRA INFO: Very rare ECU and very sought after. Simply plug and play for big power gains. No need for wiring or mapping, just plug in and away you go! Ran very well in the car before removed and gave excellent power gains. The JAM ECU: Raises rev limit to 8000rpmRemoves the 180 km/ph speed limiterRemoves fuel cutBoasts an aggressive map for more power and torqueSuitable for various setupsAdvances timingIt raises the fuelling to cope with the increased powerPRICE: £520 including express courier delivery fully tracked to the UK or IrelandLOCATION: Dublin, IrelandDELIVERY TERMS: Courier, post, collection or can meetCONTACT INFO: PM Browner or contact Conor on (00353) 86 378 4399PICTURE:
Mr. Chem Posted April 30, 2013 Posted April 30, 2013 Hi Browner, What supporting mods is this ECU set up to use? Or what did the last car have on it? Cheers
scottyb Posted April 30, 2013 Posted April 30, 2013 Hi Browner, What supporting mods is this ECU set up to use? Or what did the last car have on it? CheersYou can use it on alot of things from totally standard to td04. As far as i know though theyre best suited to ct9 and ct9 hybrid with mods like fmic, mani, decat etc.
Mr. Chem Posted April 30, 2013 Posted April 30, 2013 Do any modifications to the fueling need to be made? I'm running a CT9 with decat, ARC intercooler (TMIC) with a system to cool the charge by spraying the cooler. Would I need to consider a better fuel pump? Cheers
Mr. Chem Posted April 30, 2013 Posted April 30, 2013 Maaad. Cheers guys, still getting used to Japanese cars. German stuff is all by the OBD port.
TurboTobz Posted May 1, 2013 Posted May 1, 2013 Maaad. Cheers guys, still getting used to Japanese cars. German stuff is all by the OBD port.And the maf and lamda error codes ;)
