Genuine JAM Racing Plug & Play Performance ECU (EP91)
ITEM: JAM Racing Plug & Play ECU (EP91)
CONDITION: Excellent. Working perfectly.
EXTRA INFO: Very rare ECU and very sought after. Simply plug and play for big power gains. No need for wiring or mapping, just plug in and away you go! Ran very well in the car before removed and gave excellent power gains.
The JAM ECU:
Raises rev limit to 8000rpm
Removes the 180 km/ph speed limiter
Removes fuel cut
Boasts an aggressive map for more power and torque
Suitable for various setups
Advances timing
It raises the fuelling to cope with the increased power
PRICE: £520 including express courier delivery fully tracked to the UK or Ireland
DELIVERY TERMS: Courier, post, collection or can meet
CONTACT INFO: PM Browner or contact Conor on (00353) 86 378 4399
PICTURE:
Hi Browner,
What supporting mods is this ECU set up to use?
Or what did the last car have on it?
Cheers
You can use it on alot of things from totally standard to td04. As far as i know though theyre best suited to ct9 and ct9 hybrid with mods like fmic, mani, decat etc.
Do any modifications to the fueling need to be made? I'm running a CT9 with decat, ARC intercooler (TMIC) with a system to cool the charge by spraying the cooler. Would I need to consider a better fuel pump?
Cheers
