Loctite super glue i used it on my fse got told to put the fittings in finger tight with super glue and a but once there in around the bottom. I tell you now mate they are in there worked a treat never leaked since. That came from fse them self im sure it would be the same for the sard :D
PTFE will break down over time due to the additives in fuel.
Loctite produce a specific thread sealant right for the job.
Had mine off a few weeks ago after about 5 years of running and the tape was completely intact.
yeah vaccum hose off and set to 2.3 bar if you wanna run stock fuel pressure otherwise set it with a wideband
Edited by russ78
