mikey4410 Posted July 10, 2013 Share Posted July 10, 2013 (edited) do i need one ?any help wil be great Edited October 30, 2013 by mikey4410 Quote Link to post Share on other sites
WallaceGlanza Posted July 10, 2013 Share Posted July 10, 2013 PTFE (Plumbers) tape on the threads. Quote Link to post Share on other sites
mikey4410 Posted July 10, 2013 Author Share Posted July 10, 2013 is this a must then i take it ? does the ptfe tape not get eaten by the fuel ? Quote Link to post Share on other sites
TurboTobz Posted July 10, 2013 Share Posted July 10, 2013 They say they don't need it but I always run it, they have tapered threads to ensure a seal Quote Link to post Share on other sites
akyakapotter Posted July 10, 2013 Share Posted July 10, 2013 Loctite super glue i used it on my fse got told to put the fittings in finger tight with super glue and a but once there in around the bottom. I tell you now mate they are in there worked a treat never leaked since. That came from fse them self im sure it would be the same for the sard Quote Link to post Share on other sites
mikey4410 Posted July 10, 2013 Author Share Posted July 10, 2013 (edited) so what thread lock shall i use.is it blue or red tube ? definatley fuel proof ? Edited July 10, 2013 by mikey4410 Quote Link to post Share on other sites
akyakapotter Posted July 10, 2013 Share Posted July 10, 2013 not thread lock bud Super glue ill go out to the shed see if i can find what i used Quote Link to post Share on other sites
AdamB Posted July 10, 2013 Share Posted July 10, 2013 Use PTFE tape, don't glue it or you'll never get it back out!Use what the threads are designed to take. Quote Link to post Share on other sites
00joeindastarb0 Posted July 10, 2013 Share Posted July 10, 2013 PTFE will break down over time due to the additives in fuel.Loctite produce a specific thread sealant right for the job. Quote Link to post Share on other sites
WallaceGlanza Posted July 10, 2013 Share Posted July 10, 2013 On 7/10/2013 at 9:27 PM, 00joeindastarb0 said: PTFE will break down over time due to the additives in fuel. Loctite produce a specific thread sealant right for the job. Had mine off a few weeks ago after about 5 years of running and the tape was completely intact. Quote Link to post Share on other sites
Amjad Posted July 10, 2013 Share Posted July 10, 2013 I used PTFE tape on my oil sensors, good stuff Quote Link to post Share on other sites
russ78 Posted July 10, 2013 Share Posted July 10, 2013 I used pipe cement on my sard as it leaked as well Quote Link to post Share on other sites
akyakapotter Posted July 10, 2013 Share Posted July 10, 2013 superglue its the way forward Quote Link to post Share on other sites
mattyD Posted July 10, 2013 Share Posted July 10, 2013 I used silicon sealant worked a treat Quote Link to post Share on other sites
mikey4410 Posted July 11, 2013 Author Share Posted July 11, 2013 (edited) hmm,okies Edited October 30, 2013 by mikey4410 Quote Link to post Share on other sites
TurboTobz Posted July 11, 2013 Share Posted July 11, 2013 Use the ptfe it's worked for so many and if it doesn't work it's easy to remove then move on to loctite Quote Link to post Share on other sites
triple j Posted July 11, 2013 Share Posted July 11, 2013 Use a small bit ptf and keep it below the ends of the thread, be tidy with it and the fuel will never get near it. Quote Link to post Share on other sites
mikey4410 Posted July 11, 2013 Author Share Posted July 11, 2013 (edited) What did you guys do when setting fuel pressure Edited October 30, 2013 by mikey4410 Quote Link to post Share on other sites
russ78 Posted July 11, 2013 Share Posted July 11, 2013 (edited) yeah vaccum hose off and set to 2.3 bar if you wanna run stock fuel pressure otherwise set it with a wideband Edited July 11, 2013 by russ78 Quote Link to post Share on other sites
mikey4410 Posted July 11, 2013 Author Share Posted July 11, 2013 (edited) Got wideband,so could tune it. Edited October 30, 2013 by mikey4410 Quote Link to post Share on other sites
TurboTobz Posted July 11, 2013 Share Posted July 11, 2013 I did mine both ways I think vacuum offs a better way mind you but could be wrong Quote Link to post Share on other sites
mikey4410 Posted July 11, 2013 Author Share Posted July 11, 2013 U guys are awesome,thanks for all ure help !!! Quote Link to post Share on other sites
mikey4410 Posted July 11, 2013 Author Share Posted July 11, 2013 (edited) Ptfe tape works,will try if i buy Edited October 30, 2013 by mikey4410 Quote Link to post Share on other sites
