tatep82 Posted November 20, 2013 Author Posted November 20, 2013 (edited) We gave the engine a good service, new oil and fuel filter, engine oil. Gearbox oil, new coolant. Fitted my new triple core rad with new yellow hosesTuning developments low temp thermoNew stainless steel wepr td04 turbo kitTuning developments braided oil and water linesNew magnacore ht leadsTial wastegate with 0.8 spring Iridium spark plugs Tdo4 turbo with 23k miles look new and no play at allNew Toyota gaskets Edited November 24, 2013 by tatep82 Quote
tatep82 Posted November 20, 2013 Author Posted November 20, 2013 Fitted a zisco c pillar bar too still got lots to do and clean :-) Quote
Kingcarr Posted November 20, 2013 Posted November 20, 2013 Looking good! Can't wait to see it on the road... Quote
tatep82 Posted November 21, 2013 Author Posted November 21, 2013 Thanks chaps plenty more to do :-) neither can I my freind Quote
jimmymac101 Posted November 21, 2013 Posted November 21, 2013 loving the wheels completely white mate ;) good work james Quote
tatep82 Posted November 21, 2013 Author Posted November 21, 2013 thanks james looks so much fresher now Quote
Matt1878 Posted November 21, 2013 Posted November 21, 2013 Preferred the purple but obviously that's my taste! TD04 kit was always ment for this car! Good stuff Quote
tatep82 Posted November 21, 2013 Author Posted November 21, 2013 cheers lads! sure was matt can not wait till shes complete and mapped!fitted the RARB tonight. Quote
tatep82 Posted November 24, 2013 Author Posted November 24, 2013 Spent a few hours at nights this week with the old girlFitted the white line rear anti roll bar and drop linksSard rrfprJd engine damperTein strut braceWalbro fuel pumpFitted the twin core rad properly New silicone hose for the inter cooler piping and clampsMade a Relocation air filter to suit td04Relocated oil catch tankTest fitted front varis bumperBrand new Bosch batteryWe made our own brackets for the rad out of stainless steel welded them to my chassi and cut the old bracket off to make her sit flush in the bay and some rubber felt to sit the rad on so she won't chafe, done a good job if I do say myself was my mates idea, put all new silicone hoses on the inter cooler as they was looking old also new claps as a few dint want to tighten up we changed all the pipe work too as it was rubbing on the chassi looks and fit much better, made a relocation air filter with a bend of silicone pipe we had left fits perfectly and sits in a great place, fitted a wabro fuel pump we changed the plugs over from the pumps which was a right bitch took a good hour to get the bloody things apart but now she's fitted and moans more then my misses!!!! Also test fitted the varis but not happy with the fitment but tbh all which I have seen never look great! Gave her a bloody good clean too well deserved! Shes coming along nicely now just need some brake discs and rear brake calliper!! Hopefully got everything else it just needs fitting :-)Here's a few snaps! And last of all my management and boost controller ready to fit when I go to the tuners! Quote
wickedep Posted November 25, 2013 Posted November 25, 2013 looks nice mate.i've put two of your pics on our fb page. please feel free to tag yourself mate Quote
tatep82 Posted November 25, 2013 Author Posted November 25, 2013 thanks dude!! I will take a look now, your work on the kit looks awesome glad I went for stainless looks brilliant Quote
tatep82 Posted November 25, 2013 Author Posted November 25, 2013 Cheers John In the workshop working hard as usual on her ;-) Quote
tatep82 Posted December 3, 2013 Author Posted December 3, 2013 since the other weekend i havent reaslly done too much, found a few problems which i did not really want to! the wiring of the rear lights was awful wires been cut and connected everywhere! removed 4 wires and everything still works as it should god knows why they was there looks loads neater now, the wiring to the head unit is very dangerous bare wires!!!! could not beleive it when we looked under the steering wheel coloumn also used household wire, had the car running till the thrmostat opend and the fan come on to check it was spinning the right way, and it was! but the engine management light came on not got any vac hose from turbo to wastegate could thast cause this? got new hel braided brake lines fitted, front drilled & grooved discs, yellow stuff pads and reconed the 2 front brakes, got them all fitted tonight just need to bleed them at the weekend. still plenty to do! hopefully upload some pics at the weekend Quote
Kingcarr Posted December 4, 2013 Posted December 4, 2013 If you haven't got the loop on the solenoid, that causes issues, but tubby to actuator won't as there's no sensors etc! You need to do the diagnostics ideally, it could be anything from a loose connector to a duff sensor or even a vac line off somewhere ! If you've only had it on idle ( below 2400 revs, it won't be the knock sensor... Quote
tatep82 Posted December 4, 2013 Author Posted December 4, 2013 I will have to check it at the weekend mate see what it says hopefully it's a nice easy fix. Quote
Kate Posted December 4, 2013 Posted December 4, 2013 Car looks fresh! Ps I see some Blueprint parts (thumbs up)! I work for them haha! Quote
