Ollieh17 Posted August 14, 2013 Posted August 14, 2013 Bought a 'R' reg Glanza V a few weeks ago and it only came with one standard key. When I lock the drivers door it only occasionally locks the passenger door too, however the door lock button in the car works as it should. My questions are: Can I buy a OEM remote fob, then program it to unlock and lock all the doors, or will I need to install an aftermarket system? If not: What could be causing the intermittent fault with only one door locking? Quote
StuDoc 72 Posted August 14, 2013 Posted August 14, 2013 If its only locking the other side occaisionally then there something you need to figure out. 1. There may be a technique as in you turn it a certain way or distance. 2. A switch must be in a correct position. 3. You have a sticky soleniod. Quote
Ollieh17 Posted August 14, 2013 Author Posted August 14, 2013 Cheers, i'll have a look tonight. What about remote central locking, should may car have this installed and just need a replacement key fob?Any help is great. Quote
TurboTobz Posted August 14, 2013 Posted August 14, 2013 you can get a replacement fob there about £30 and take all of 30 seconds to program you can do it yourself, no need for any other equipment. Quote
TrisK Posted August 14, 2013 Posted August 14, 2013 you can get a replacement fob there about £30 and take all of 30 seconds to program you can do it yourself, no need for any other equipment.Providing you have the sensor and you car had it from factory Quote
Ollieh17 Posted August 14, 2013 Author Posted August 14, 2013 Is there a way to check my car had it from factory? Quote
Ollieh17 Posted September 4, 2013 Author Posted September 4, 2013 bump.Need a way to make sure my car has the capability of remote central locking Quote
TrisK Posted September 4, 2013 Posted September 4, 2013 Post of a photo of your rear view mirror Quote
Ollieh17 Posted September 4, 2013 Author Posted September 4, 2013 Photo of my rear view mirror. Is the black bit a recievet? Quote
mm2101 Posted January 28, 2014 Posted January 28, 2014 mine is doing this also, i have the box at the rear view mirrior but not the black thing like the picture above? Quote
fremyjay Posted January 29, 2014 Posted January 29, 2014 I have a spare fob knocking around, in working condition Quote
Ollieh17 Posted January 29, 2014 Author Posted January 29, 2014 I have a spare fob knocking around, in working condition pm me bud! Quote
StarletSr? Posted January 29, 2014 Posted January 29, 2014 Can you buy these new? Or is second hand the best option? Quote
Ollieh17 Posted January 29, 2014 Author Posted January 29, 2014 Can you buy these new? Or is second hand the best option?Can you buy these new? Or is second hand the best option? you can buy them new from toyota mate Quote
Banbury Glanza Posted January 29, 2014 Posted January 29, 2014 Pretty sure this is the part number 89742-10010 they are around £40 I think. Quote
Jay85 Posted January 29, 2014 Posted January 29, 2014 Is the censor in the same place in the gt's?? Quote
Shwdii Beii Posted January 31, 2014 Posted January 31, 2014 never had mine working on a fob! will be buying one now! how easy is it to program? Cheers Sion Quote
Ollieh17 Posted January 31, 2014 Author Posted January 31, 2014 Pretty easy mate, have tried it on another fob i have but didnt work as it was the wrong one http://www.toyotagtturbo.com/forums/showwiki.php?title=EP91+Remote+locking+fob+-+programming+procedure Quote
Shwdii Beii Posted January 31, 2014 Posted January 31, 2014 that is pretty easy! will have to get one ordered Cheers man! Quote
hookie663 Posted January 31, 2014 Posted January 31, 2014 Yes that's the right part number 32.55 inc vat I tink Quote
