Pobbette Posted August 29, 2013 Posted August 29, 2013 Any advice? I tried to do this at the weekend, but had trouble getting the filter off. I used one of those tools but still could not get it off. Am i being really dim? It is in such a tight space that i just gave up and did the oil change for the time being. Any help will be appreciated Quote
rinseep82 Posted August 29, 2013 Posted August 29, 2013 What I do when I can't get it off is go in from underneath and bang a screwdriver threw it then twist off Quote
Chesh Posted August 29, 2013 Posted August 29, 2013 bang a screwdriver threw it then twist off X2 Quote
DavidAshton Posted August 29, 2013 Posted August 29, 2013 I use one of these and I have never had an issue. Wouldn't attempt an oil change without it. It also helps if you don't have air con makes it so much easier without the pump in the way. Quote
StuDoc 72 Posted August 29, 2013 Posted August 29, 2013 I assume the problem is that you still have your aircon fitted? 3 bolts and the A/C pump will drop out the way and make it alot easier. You can try the screwdriver trick but its a bit messy and there are much better ways plus its big no no in the car world. Also you will prob need to change the oil again since you left on the old filter with new oil. Quote
JayJ Posted August 29, 2013 Posted August 29, 2013 (edited) edit: all is said already :-D Edited August 29, 2013 by JayJ Quote
Pobbette Posted August 29, 2013 Author Posted August 29, 2013 (edited) Thanks guys! Yes still have air con on so will take the pump off. Yeah I know I got to change the oil again but I already drained the oil out before trying to get the filter off so had to put some in Will try again this weekend if it have time around moving house Shame none of the men in my life want to help me lol!!! Edited August 29, 2013 by Pobbette Quote
daniel_g Posted August 29, 2013 Posted August 29, 2013 I use this, oil filter claw. http://www.subaruforester.org/vbulletin/attachments/f88/12904d1215990850-filter-wrench-oem-oil-filter-oil-filter-claw-wrench.jpg Must have used it literally hundreds of times without fail Quote
5T4R7ET N/A Posted August 30, 2013 Posted August 30, 2013 picked up one of these from a local parts store. £5 cant go wrong. you will have to take the splash guard off and unscrew from underneath. http://www.ebay.co.uk/itm/215mm-Oil-Filter-Chain-Wrench-Remover-8-5-Fuel-Strap-Removal-Tool-/251274561422?pt=UK_Hand_Tools_Equipment&hash=item3a8121878e Quote
