Item For Sale: Tuning developments stage 2 forged engine&accessories
will also come with the following
bare glanza shell on oem suspension..doors/dash/
td fuel pump/td low temp thermo stat/pcv/new rotor arm & dizzy cap/ 1x powerflex engine mount/magnetic sump plug.
**if this sells my glanza will be getting broken BUT if only if this sells first **
this is not a breaking thread :thumbsup:
Item Condition & Description: 1000 miles on the engine its new :thumbsup:
Engine
Tuning developments stage 2 fully forged engine- fully run in with 4 oil changes and oil filters
Wossner 74.5mm Low Compression Piston Kit with Rings and Pins
Scat 4EFTE Forged Conrod Kit with ARP Rod Bolts
Athena 1.2mm Uprated Metal Headgasket
ARP 2000 Uprated Headbolt Kit inc New Washers
Genuine Toyota Full Gasket Kit
Genuine Toyota Oil Pump Kit
OEM Water Pump Kit
OEM Cambelt Kit inc Idler & Tensioner
ACL Main Bearing Kit
ACL Big End Bearing Kit
ACL Thrust Washer Kit
Fully Machined and Polished 4EFTE Bottom End
Fully Stripped, Cleaned and Rebuilt 4EFTE Cylinder Head to Standard Spec
Block, Head and Rocker Cover Cleaned and Painted in our Tuning Developments Black and Silver The
Price: £2200
Payment & Shipping Details: pick up only
Edited by iamlegend
Is this engine not £2000 from td
stage 1 is yes this is stage 2......2300 from TD bare engine thow...... this comes with
also glanza shell
again with no waiting time to build engine its ready to go
£2200
Edited by iamlegend
i messaged you about this before but you never messaged me back..
FOUND pm
PM SENT
Edited by iamlegend
Bit pricey IMO can get a new one for 2200 for TD, would have been interested in this if it was cheaper,
What would be your best price for the bare engine?
Cheers, Neil.
Cheers, Neil.
But when you buy a engine from td it doesn't come with a mint shell :)
Would only be wanting the bare engine, a mint shell is no good to me unless i can cut the engine in half and split it between the mint shell and my own car?
Never seen that done before actually but anythings possible these days.
Cheers, Neil.
really? a stage 2 engine there actually 2300 with bare engine only oh and to run it in is a extra 500 quid along with if needing dizzy cap&rotor arm etc etc adds up way past that price dude....
best price I will take is 2100.. this is with shell.. and will only be coming with shell... along with td low temp thermo stat/td fuel pump etc
Maybe he cant take it out?
never took a starlet engine out before.. do not have a engine hoist.. so yea be much better it left in with shell :) easier for me
  • 2 months later...
